It is currently Wed Jul 23, 2025 12:36 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 66, 67, 68, 69, 70, 71, 72 ... 568  Next
 Post subject: crap
PostPosted: Fri Aug 14, 2009 2:18 am
did bugger all,just enjoying the mini in all its glory
First you get the money,then you get the power,then you get the Mini.
PostPosted: Fri Aug 14, 2009 11:54 pm
just got back from a 2.5 hour drive around the district, up and down as many hills as I could find...
wodonga, yackandandah, beechworth, chiltern, albury via the rutherglen road, bellbridge, talgarno, bethanga, loop around bethanga, back to bellbridge, then latchford and back to wodonga
PostPosted: Sat Aug 15, 2009 8:39 am
Re: Spongy pedal
Matt, A good trick Colin at Brookers brakes told me when I was having problems, Clamp each of the four brake hoses to close off and hit the pedal. Soft pedal = master cyl
Hard pedal = good master problem else where.
Next release one at a time. one rear first, test pedal, this will point you to the problem wheel / area.
Also look for Matt Reads post, really good should be a "how to" ah Jim :lol:
found another item
http://www.ausmini.com/forums/viewtopic ... ht=#656884
"Boris" - '69 Cooper S Mk 2
PostPosted: Sat Aug 15, 2009 9:22 am
I hear you Steve and once I have a free weekend :lol: i'll do one on brakes and put it to the other Mods and a few of the experts which Ill also included that tip above also.
Steve you haven't mention you did something for your S. Your Driveway is so much nicer for Boris to accsess his Bed
Myself just Bling the Fuel bowl of the 1 1/2 Su still 3/4 finished the 400 grit
PostPosted: Sat Aug 15, 2009 10:24 am
Might cut out some tin worm. Start removing floor...... :)
PostPosted: Sat Aug 15, 2009 10:56 am
OK Jim.
Yes shiny new drive, now Kev can drive down easy.
Concretor said, "no need to brake now". :shock:
PostPosted: Sat Aug 15, 2009 2:32 pm
Milatsmadmini
great pic Steve,
what do i use to clamp the lines? locking pliers of pegs or something?
thats actually a really logical way of doin it i spose... ta for that.
got my modified rear bar back and painted it up today ;)
PostPosted: Sat Aug 15, 2009 2:37 pm
Ordered the shockers from MiniSpares along with a locking petrol cap and some knuckle joint shims
David L
PostPosted: Sat Aug 15, 2009 3:09 pm
Worked on Slidey
Found a coolant leak inside the cabin, heater hose was void of hose clamp. Fixed that.
tried to start the new 1360. It turned over (got oil pressure too) but wouldn't fire!!!!
I think that I'll have to pay someone to get it going.
trying to get it going for the Muster
PostPosted: Sat Aug 15, 2009 3:17 pm
T.K
Post your check list for startup and ask for help.
Soooo many people here can help at no cost.
PostPosted: Sat Aug 15, 2009 4:27 pm
Welded up the door lock area on a RH Deluxe door for 13secmini.
Some clown had torn it all away, I had to put my tissue paper MIG welding skills to use (again)..:mrgreen:
PostPosted: Sat Aug 15, 2009 8:21 pm
I put another freebie 998 in the shed with it :)
PostPosted: Sat Aug 15, 2009 8:59 pm
installed the twin 11/4' S.U.s again .this time i'm having more success. :D
PostPosted: Sat Aug 15, 2009 9:15 pm
4myego wrote:
OK Jim.
Looks Much better...Kev :lol: I hope my scrapping your gutter in the Alfa didn't force you into it
PostPosted: Sun Aug 16, 2009 1:43 am
NAV-MAN
I finished assembling NAV's engine and put it back in. Forgot to get some oil :oops: :roll: so can't start it yet. At least it stopped me from rushing to start it.
1st time i've ever assembled and engine so i hope it runs.
