It is currently Thu Jul 17, 2025 11:46 pm
Post new topic Reply to topic  [ 135 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9  Next
PostPosted: Sat Aug 15, 2009 8:28 pm
Super-mini wrote:
can we just overbore to 998 size pistons? and how many thou is that over std?
Overbore about .060" and you can fit stock 998 64.6mm pistons.
You will need to deck the block by about .156" though, as they are shorter pin to crown height.
Is any of that an issue?
Is there enough metal in the block for both operations?
895cc with a better bore/stroke ratio sounds interesting.
PostPosted: Sun Aug 16, 2009 12:21 pm
Looking at some specs, i notice that there's a 0.065 inch difference between 850 and 998.
PostPosted: Sun Aug 16, 2009 2:12 pm
Cush there is no problem with boring, back in the 60s I used to overbore 850s and stick a new 1098 crank, rods and pistons in em.
The major mod was to the 850 centre main cap and block, to allow the 1098 crank to fit (its bearings are narrower). Won't affect you with an 850 crank. :wink:
PostPosted: Sun Aug 16, 2009 2:52 pm
cush wrote:
Wombat wrote:
I have a set of STD 998 pistons -NOS I could be encouraged to part with :wink:
'ow mooch?
Make an offer less than you would have to pay from Minispares with postage at a price you would be happy to pay as a 'fair' price.
David L
PostPosted: Sun Aug 16, 2009 6:27 pm
Ohh. that's exciting...
SO what's the deal with overbore sizes..
SP64 Specs tell us that 998 is 2.543 in. does that mean the bore is 0.2543 and the piston is actually marginal smaller or is it the other way around?
PostPosted: Sun Aug 16, 2009 6:35 pm
Wombat wrote:
cush wrote:
'ow mooch?
That's a decent option, thanks.
I'll keep that in mind ;)
PostPosted: Sun Aug 16, 2009 6:44 pm
2.543" is the actual bore size. Piston is a couple of thou less. :wink:
But best to not bore it until pistons are available to hand...
PostPosted: Sun Aug 16, 2009 8:29 pm
Whilst i think i know the answer..
I've got a good 998 block here with (surprise surprise) 998 std pistons, I could just use those, yeah?
The bores look look fine and i trust the previous owners opinion that all the block needs would be a re-ring (and i know you don't believe in that. ;) )
I trust his opinion, because the PO was 50% of the duo that killed the mini 1000 series way back when... :P
PostPosted: Sun Aug 16, 2009 9:56 pm
don't use old pistons - new ones are too cheap
PostPosted: Sun Aug 16, 2009 10:00 pm
even 998 stockies?
PostPosted: Mon Aug 17, 2009 9:16 am
cush wrote:
even 998 stockies?
Yeh you need new standard stockies :wink:
David L
PostPosted: Mon Aug 17, 2009 9:37 am
Are 998 stockies actually available new?
Edit... yep.. 170 from the Kraft
PostPosted: Mon Aug 17, 2009 5:12 pm
:roll:
David L
PostPosted: Tue Aug 18, 2009 1:30 am
Cush, If you want .020" and .040" oversized 850 pistons and rings then try your nearest Autopro shop.
The bloke I deal with at autopro in gawler can get a new set of pistons and rings for around $200
If you are building a stock eng then JP pistons also sell 850 pistons.
If you want 998 pistons Autopro can get them as well. There are some pistons available that have a pressed in gudeon pin instead of those nasty circlips and floating pins. The rod needs to be reamed out about .003" . The pistons have a cutaway skirt where the gudeon pin is but only have 3 rings.
www.minisprintgt.com
PostPosted: Tue Aug 18, 2009 7:13 am
Don't forget 850s here had that `clamp bolt' little end in the rod. You would need to grind a notch in the gudgeon pins to fit 998 pistons (IMO not a great idea) or fit 998/1098 rods. Same length etc and fit fine.:wink:
