It is currently Thu Jul 17, 2025 4:09 pm
PostPosted: Mon Aug 17, 2009 7:20 pm
Im interested to see other people's oil pressure?
Mine is (Hot):
Idle:35psi
Freeway: 51psi
Also is there a way to adjust oil pressure via a relief valve like on a mini?
PostPosted: Wed Aug 19, 2009 10:37 pm
Mine's about that too. probably a bit lower. around 30 idle & 45 freeway (ish) :wink:
-James.
Toyota 4EFTE Powered Minivan.
PostPosted: Thu Aug 20, 2009 10:01 am
What oil are you running?
I'm using Castrol Edge 20w50 but thinking of going something slightly heavier like Penrite HPR15 20w60
PostPosted: Thu Aug 20, 2009 10:10 am
This space for rent
What's wrong with 45-50 PSI hot? Sounds like enough to me..
The oil pump has gotta have a pressure relief / regulating valve somewhere, question is whether it's externally accessible like on the A-series.
PostPosted: Thu Aug 20, 2009 10:16 am
I have spoken to a few people and with the extra boost i'm running (~20psi) and higher rev's (7,800rpm) they would like to see it a bit higher..
PostPosted: Thu Aug 20, 2009 11:16 am
I'm running Castrol Edge 10W30. All the manuals I've got say recommended oil is 10W30. My engine is basically stock, so I've stuck to this. The oil pressure seemed pretty good to me.
Try posting the question on the Austarletclub forum. More 4eftes there. :wink:
-James.
PostPosted: Thu Aug 20, 2009 11:37 am
Yeh i did a search as it's been asked before, their oil pressure seems a little higher and they all swear by HPR15...
PostPosted: Thu Aug 20, 2009 11:41 am
This space for rent
Err.. yeah, fair enough. More is probably better in your case then :lol:
