It is currently Sat Aug 16, 2025 5:32 am
 Post subject: Mini K gearbox??
PostPosted: Thu Aug 27, 2009 10:09 pm
Anybody know if a Mini k remote change gearbox has a syncro on first and can the inards be put in a rod change is there much difference.
PostPosted: Thu Aug 27, 2009 10:16 pm
Yes a K box has 1st gear synchro.
Yes all the gears, layshaft and mainshaft will fit the A series (not A+) rodchange box, except reverse.
But the selector setup is different, so you need to use the rodchange ones.
 Post subject: Thanks!!
PostPosted: Thu Aug 27, 2009 10:20 pm
Great thtas what i wanted to know.cheers.
PostPosted: Thu Aug 27, 2009 10:22 pm
This space for rent
If you've got a remote box, keep it rather than gutting it for a rodchange case. The gearshift is usually more precise, and the housing keeps the engine lots more steady than the rodchange unit...
Users browsing this forum: Bing [Bot] and 308 guests
