It is currently Fri Aug 22, 2025 8:27 am
 Post subject: Gear stick problems
PostPosted: Fri Aug 28, 2009 10:27 am
So i dont actually know what this part is called so i thought a picture would be the best idea.
so now that this piece has snapped the gear stick wobbles free and obviously thats not right
Question: can this just be welded back together? or are parts going to be needing replacement?
Lachy
PostPosted: Fri Aug 28, 2009 10:36 am
Which bit, the rubber "cottonreel" bolt part or where it bolts to the floor. The cottonreel rubber bits are available from any mini distributor generally under the exhaust sections, pretty cheap ~$10 max.
2008 Prado GXL
PostPosted: Fri Aug 28, 2009 10:46 am
Just unbolt the busted bracket, weld it up and refit.
PostPosted: Fri Aug 28, 2009 10:48 am
unfortunately its not the cotton reel part...its the little strip that connects that bit to the gear assembly thingo
this bit here
PostPosted: Fri Aug 28, 2009 12:03 pm
It's a steel bracket.
Anybody with a welder can fix that, even your local zorst place. :wink:
PostPosted: Fri Aug 28, 2009 4:54 pm
nobody likes a stick in a jar of marbles :lol:
PostPosted: Sun Aug 30, 2009 10:56 am
ive taken the piece off and am wondering what sort of weld i should use?
electric? mig? does it matter?
PostPosted: Sun Aug 30, 2009 12:53 pm
mig if you got it probably depends more on your welding skills 8)
PostPosted: Sun Aug 30, 2009 1:39 pm
The bracket broke on mine last week in exactly the same spot.
Took it out, welded it and threw it back in all in less than 45 minutes.
Strange thing was that it seemed to go in to gear a lot better when the bracket was broken! It might have just been because everything was flopping about.
Good luck.
1978 Mini S - "FAX"
PostPosted: Sun Aug 30, 2009 1:40 pm
so if i have uber skills i could just use crazy glue?
PostPosted: Sun Aug 30, 2009 1:41 pm
Good luck.
things dont usually work like that, usually harder to get into "gear" when its floppin about
PostPosted: Sun Aug 30, 2009 1:43 pm
Thats why it seemed strange!!!
Only drove it for about 10 kays after it broke.
1978 Mini S - "FAX"
PostPosted: Sun Aug 30, 2009 5:20 pm
and rubber bands :)
