It is currently Thu Aug 14, 2025 11:10 am
PostPosted: Fri Aug 28, 2009 9:55 am
I found this for you wrote:
Frequencies
Channel 11 is designated as the "Call Channel" to allow you to call other stations, however in many city areas local repeaters are used as the local call channel as they provide wider coverage.
Channel 40 is used Australia wide as the "Road Channel" extensively used by Truck Drivers for safety communications and traffic updates however due to interference between the New England and Pacific Highway communications, truck drivers between Sydney and Brisbane use channel 29 if they are travelling via the Pacific Highway.
Channel 18 is used for "Caravan & Motor Home" users Australia Wide.
Users should not use channels 31 to 38 as they are the automatically selected "Transmit" channels for repeaters on channels 1 to 8. Users who wish to use a repeater should choose a channel between 1 and 8 and press their "Duplex" button,
UHF CB Channel Allocations Channel Frequency Purpose
1 476.425 Repeater Channel (Press DUPLEX to use)
2 476.450 Repeater Channel (Press DUPLEX to use)
3 476.475 Repeater Channel (Press DUPLEX to use)
4 476.500 Repeater Channel (Press DUPLEX to use)
5 476.525 Repeater Channel (Press DUPLEX to use) (EMERGENCY ONLY)
6 476.550 Repeater Channel (Press DUPLEX to use)
7 476.575 Repeater Channel (Press DUPLEX to use)
8 476.600 Repeater Channel (Press DUPLEX to use)
9 476.625 General Chat Channel
10 476.650 General Chat Channel
11 476.675 Call Channel - used in areas with no repeaters - To call other stations.
12 476.700 General Chat Channel
13 476.725 General Chat Channel
14 476.750 General Chat Channel
15 476.775 General Chat Channel
16 476.800 General Chat Channel
17 476.825 General Chat Channel
18 476.850 Caravan, Campers & 4WD Road Channel
19 476.875 General Chat Channel
20 476.900 General Chat Channel
21 476.925 General Chat Channel
22 476.950 Telemetry and Telecommand Only
23 476.975 Telemetry and Telecommand Only
24 477.000 General Chat Channel
25 477.025 General Chat Channel
26 477.050 General Chat Channel
27 477.075 General Chat Channel
28 477.100 General Chat Channel
29 477.125 Road Channel (Pacific Highway between Sydney and Brisbane only)
30 477.150 General Chat Channel
31 477.175 Repeater Input Channel (Not for use - See Below)
32 477.200 Repeater Input Channel (Not for use - See Below)
33 477.225 Repeater Input Channel (Not for use - See Below)
34 477.250 Repeater Input Channel (Not for use - See Below)
35 477.275 Repeater Input Channel (Not for use - See Below)
36 477.300 Repeater Input Channel (Not for use - See Below)
37 477.325 Repeater Input Channel (Not for use - See Below)
38 477.350 Repeater Input Channel (Not for use - See Below)
39 477.375 General Chat Channel
40 477.400 Australia-Wide Road/Truckies Channel (excluding Syd->Bris via Pacific Highway where 29 is used.)
Note: Users should not use channels 31 to 38 as they are the automatically selected "Transmit" channels for repeaters on channels 1 to 8. Users who wish to use a repeater should choose a channel between 1 and 8 and press their "Duplex" button
:lol:
Drexxle loves chocolate salty balls wrote:
:P
manufacturers of illegal linear amplifiers (such as Fat Boy and Palomar Engineering) openly advertising their products for sale, and many CB dealers carry these and other amplifiers in their product lines and include them in catalogs.
PostPosted: Fri Aug 28, 2009 5:24 pm
Frequencies
Channel 11 is designated as the "Call Channel" to allow you to call other stations, however in many city areas local repeaters are used as the local call channel as they provide wider coverage. etc.
Awesome info thanks scott. 8) :D
I have this antenna http://www.dse.com.au/cgi-bin/dse.storefront/4a9783f600d62748273fc0a87e0106a9/Product/View/D4007, and its currently mounted on the side guard where the original radio antenna is, its a 178cm antenna. Had good reception over a known 7 km's or there abouts so far. The 400sx is a 5watt UHF, the guy at the 4x4 place said i should get 20-30km range from it. Maybe i should look at a 4.5db antenna for use around the city.
Say Everybody have you seen my balls, their big and salty and brown. If you ever need a quick pick me up, just stick my balls in your mouth. --- CHEF!!! :lol: :lol: :lol: :lol: :lol: :lol:
PostPosted: Fri Aug 28, 2009 5:32 pm
If you want to improve the range you really need to drill a hole in the middle of the roof. Anything else is just a waste of effort.
PostPosted: Fri Aug 28, 2009 5:40 pm
Drexxle, I'm interested in why you are going UHF. Seeing you're foraying out into the wild sticks, I would have thought the longer wavelength of the VHF or HF wavelengths would have been your choice?
PostPosted: Fri Aug 28, 2009 5:45 pm
Long term benefits, i bought a handheld pack as well. Ill only be in the outback for a short time, probably 6-8weeks. All those caravan towing grey nomads use UHF as well, and there are plenty of them in the outback. Ill be able to use the radio when i go on a run in the years to come, and i can give handheld to a mate if he doesnt have in car unit.
I saw a VHF unit on sale but it was gone when i bought mine, and they were three times the cost.
PostPosted: Fri Aug 28, 2009 5:49 pm
I have put a roof cage and racks on the car, so i will look into a mount that can bolt to the side of the cage, i could run a cable up the windscreen pillar and along the cage from the mount at the original radio antenna hole. Then i can have the best of both worlds, a spot to mount when the cage is off, and a spot on the cage to mount when im using it.
Users browsing this forum: No registered users and 292 guests
