It is currently Tue Jul 22, 2025 7:48 am
Post new topic Reply to topic  [ 113 posts ]  Go to page 1, 2, 3, 4, 5 ... 8  Next
PostPosted: Tue Mar 08, 2005 6:56 pm
Well it's all going to plan, I've got the 1360 auto block, rods, pistons & cam back, will get S crank back tomorrow. All being well I can start to screw it together this weekend. May be running again by Monday 21st.
Yeehah! :P
Sorry rice dudes.. no turbos, NOS, blowers, stroker cranks etc. It'll be just like before, but with `a bit more' power and a shorter (3.647) diff. 8)
PostPosted: Tue Mar 08, 2005 7:43 pm
Any hints on what cam will be used kev?? Ill pop around on monday if im in your area and give you hand if you want. How is barney going now after a couple of weeks of motoring.
1974 Moke - 998cc
PostPosted: Tue Mar 08, 2005 7:51 pm
I'm thinking that there will be a "Secret" GR Cam inside....
I'm thinking that the RE-13 has had a lot of developmen, and now its time to get a little more civilised, and even more powerful.... yes Kev ?
hmmmm... i may have to wind some more boost in i think , 73, just aint going to cut it..... :-)
J
PostPosted: Tue Mar 08, 2005 8:40 pm
Hmm...nice 8)
I think GR has a new cam that's even bigger than the RE-13 ;)
Do you change how much power makes it to the ground when you change gearing at all?
<edit> I'm thinking not..it just maximises the effective use of the power
PostPosted: Tue Mar 08, 2005 8:48 pm
hehehe....pretty appropriate thread title, with easter coming up and all....
EDIT: Sorry...thought it said resurrection..... :lol:
It is a kinda resurrection anyways......
PostPosted: Tue Mar 08, 2005 8:56 pm
J
Nah don't worry- the cam will be the good old `revised' RE-13, same as Gaf and Mini Mad are running. But I'm using 1.5 rockers for more top end sizzle.
There is a new killer street cam coming but it's not out of gestation yet.
I'll shove one of those in my next motor, which will be a 1430.. 8)
PostPosted: Tue Mar 08, 2005 9:07 pm
Why is it 'revised'?..you'll just be using the same cam? or was your original RE-13 grind different?
PostPosted: Tue Mar 08, 2005 9:10 pm
Mine was different. More top end, but less midrange. Now it's the same as yours.
It'll still have good top end- I've had the die grinder in the head, again... :P
PostPosted: Tue Mar 08, 2005 9:15 pm
Haha, you just can't help yourself can you :lol: Good to see james is keeping you on your toes ;)
PostPosted: Tue Mar 08, 2005 9:17 pm
My (turbo) head gasket is stronger than HIS (998) head gasket.. :lol:
He can only run so much boost.... I hope! :oops:
PostPosted: Tue Mar 08, 2005 9:56 pm
Just you just lov it when it starts coming together...
Congrats Kev..and I knew you would have a play with the Head :lol:
PostPosted: Tue Mar 08, 2005 10:18 pm
i am expecting it will be more impressive than Mini-Ha-Ha pre february 2005?
hey doc, what sparked off his resuscitation?
Inconspicuously Conspicuous
PostPosted: Tue Mar 08, 2005 10:22 pm
Hay mate are you still going to do the Bench Dyno :arrow:
PostPosted: Wed Mar 09, 2005 5:50 am
I was going to go the cheapo route of just replacing his cracked piston and fitting new rings, but by the time I strip it all down it's not worth it.
So I'm building my spare motor to put in, it's now got 1360cc Hypatec pistons, S crank & rods.
The old motor in car might yet get a stroker crank.. and be rebuilt to a 1430... for next time!
PostPosted: Wed Mar 09, 2005 9:29 am
Mini Ha Ha going faster than it already is! :shock: now that's a scary thought! I'll pop around next weekend for a squiz Kev! Sounds awesome!
Users browsing this forum: acarseldine and 97 guests
