It is currently Sat Jul 19, 2025 10:04 am
 Post subject: max boost??
PostPosted: Fri Aug 28, 2009 8:02 pm
Hi all
When i was in england and went to santapod raceway i saw a red mini (roundy) do the 1/4 mile in 12.XX seconds. i thought boy that was quick and went and found him lining up for the next run.
I asked to have a look under and he was running a tubo with a metro engine and it looked standard to me he also said the insides were pretty standard as well.
His car was pretty standard looking as well, i know he had no rear seat. (was not a kitted out full race car)
I asked what boost he was running and he said 18-20 boost, he also said he rarely blows head gaskets now and was putting out about 199HP (rolling road)( I know these need to takn with a grain of salt, but still thats a huge amount of power from an a-series)
I just wish i grabbed a snap or two.
Is this likely is this to be correct?
Is that boost sustainable?
Because it was seriosly quick, for a fairly stock looking car and motor
PostPosted: Fri Aug 28, 2009 8:15 pm
I saw the car aswell it was very quick
You will find that he doesn't run that sort of boost all the time only for the track, and it would be correct at 18-20psi. To do 12's big HP is needed for a standard weight car.
An A series running this sort of boost and making this sort of power will not do lots of km's so will need rebuilding/checking regularly to prevent failure.
4efte powered Clubman
supercharged 998 race car
PostPosted: Fri Aug 28, 2009 8:24 pm
ah awesome someone else saw it as well.
Yeah i was truly amazed at this comparing it to a starlet motor times (someone here does 13 secons i think??).
And because i know VERY litttle about turboes i thought i would ask
Thanks for that 92
PostPosted: Fri Aug 28, 2009 10:18 pm
Geoff Goodliff ran a supercharged engine in his mini sprint in 1967-69 as a hill climb car with 3 bar[45psi boost] The eng had tecalemit fuel injection and the comp ratio was 6.5-7 :1. The car made 200bhp at the wheels. Check out his website.
www.minisprintgt.com
PostPosted: Fri Aug 28, 2009 11:31 pm
hey thanks David
That is incredible i didnt know you could send that much boost through a motor and it still stay together,
I did a google search, a 3 1/2 foot sprint putting out around 200bhp thats crazily scary.
I now know mini motors can hold and do a lot more than i thought.
Thanks Brenton
PostPosted: Sun Sep 06, 2009 7:44 pm
theres a yellow mini in the uk with the bmw k1100 head on it, in miniworld magazine on the dyno it ran at 210bhp at the wheels but the clutch was slipping and the turbo wasnt running full boost yet :lol: crazy power
Potato
PostPosted: Sun Sep 06, 2009 8:34 pm
Yeah that`s Jimster from Sheepspeed, he`s run up past 255hp now :-)
PostPosted: Sun Sep 06, 2009 9:20 pm
that is so insane that i want one :lol:
Potato
PostPosted: Wed Sep 16, 2009 11:36 pm
Nic's red car is very quick. Most of those fast cars are from turbominis.co.uk
Hes seems to be one of the last on a 5 port, and done on a reasonable budget.
PostPosted: Thu Sep 17, 2009 10:56 am
Thanks for that 92
That'd be me.
The engine doesn't really come into it more so than the capacity. A 1330cc A-Series vs a 4EFTE 1331cc with same turbo same boost and mods on the a-series head should make very similar power. Afterall they are both 1.3L motors.
The only difference would be in reliability, i can run 16psi all day every day and not encounter problems with engine or gearbox with stock internals.
Bloody good effort to run 12's, i'd be interested to know what tyres he was using? If i put drag slicks on mine it would probably take another second off.
PostPosted: Thu Sep 17, 2009 2:00 pm
Thanks Mini Mad, i unerstand now
Wow that 200+BHP at the wheels that is CRAZY!!!
Slightly diverting now
How would you stop the driveshafts from snapping?? I have mate who is in to racing minis and he said back in the day he had a mini that would put out 135 at wheels and he kept snapping driveshafts so he ended up using morris 1300 ones (it has a hole in it so you drill it out and then i think thread a bolt into it)
I also think i remember a post of yours mini mad that you kept snapping driveshafts.
PostPosted: Thu Sep 17, 2009 2:01 pm
oops double post sorry
PostPosted: Thu Sep 17, 2009 2:15 pm
Driveshafts have to be designed right and of the right material. I'm using standard mini disc CV's and on my third revision of shafts (and i can change from 5th into 2nd @ 70km/h and easily spin both wheels).
The key thing that i learned the hard was is that the shaft diameter should be smaller than the root diameter of the CV spline. This gives the shaft some flex to absorb the load.
Morris 1300 CV's fit in with some machining of the hubs or fitting a spacer but i'm of the belief/hope? that you dont need to do that :lol:
PostPosted: Thu Sep 17, 2009 8:26 pm
oh ok cool i got it now. Thanks for your help.
Thats what my mate did back in the day (umm warick augustin :D )
Dont know what hes using in his toyota on mini gearbox racecar now.
I think i need to have a chat to him about it :D
cheers fellas
PostPosted: Sat Sep 19, 2009 11:38 am
Hi Bubbacluby.
Looks like Santo Pod has opened your eyes to the limitless possibilities of spending lots of money on your Clubby? :wink:
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
