Mick, the original dimension is 25.0mm I think, but the only safe way is do a trial build with the flywheel, driven plate and drive straps.
This is because the flywheel face has probably been machined over the years too and this affects the result.
The diaphragm spring should be flat or very nearly so when assembled. I hold a 3mm twist drill against it, it should be parallel with the flywheel.
This gives maximum clamping force to the driven plate.
When the clutch is depressed, the spring goes over centre, reducing pedal effort and the force on the crank's thrust washers.
See
http://www.minimania.com/web/DisplayID/ ... ticleV.cfm for Marcel Chichak's reasons why this is important.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
