It is currently Sat Jul 26, 2025 12:03 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 74, 75, 76, 77, 78, 79, 80 ... 568  Next
PostPosted: Sun Aug 30, 2009 10:28 am
Location: Woodside, Hahndorf and Mount Barker South Australia
Just sat in her .............. waiting for a move to a new house with a double lock up garage. then it's all engines go for the rebuild ....... :D
people say keep ya friends close and you enemies closer BAH I say keep your friends close and your enemies at maximum effective range.
PostPosted: Sun Aug 30, 2009 11:12 am
Went on a 50th Birthday drive with a few other Minis :D
Weather was perfect in Perth.
**What you looking at Mate......wanna drag off the lights!!
PostPosted: Sun Aug 30, 2009 11:47 am
Chained the oil and filter, then started trying to fix the door - wouldn't unlock. Now I've fixed it and it doesn't lock. Progress...
PostPosted: Sun Aug 30, 2009 12:26 pm
Sprayed the edges of the door ready for putting the skin on tomorrow
David L
PostPosted: Sun Aug 30, 2009 1:47 pm
weather is always perfect in Perth ......*sigh* so miss W.A. ..........
PostPosted: Sun Aug 30, 2009 4:32 pm
put it back together after taking the radiator out yesterday to investigate a suspect rattle - I was paranoid that the timing chain was hitting the cover - I'm sure it's just the rockers
also changed the manifold gasket...
PostPosted: Sun Aug 30, 2009 5:42 pm
Fitted single centre Lucas driving light, wired with a separate switch to the high beam wiring , should give me a good spread of light if the convoy get's stretched out on the "Asparagus Job " . 8)
PostPosted: Sun Aug 30, 2009 7:47 pm
went to the All Brit Day and was able to drive Morris thier :wink:
PostPosted: Sun Aug 30, 2009 8:00 pm
hehe i did the same last week, just single 4inch spot (not a lucas). And it is brighter than both the headlights combined. Im going to have to convert the headlamps to relays and hal's soon.
PostPosted: Sun Aug 30, 2009 9:04 pm
I stripped a wide case 3syc gearbox ready for cleaning in the cold tank tomorrow. It will be used to build a 2nd S/C box spare for the race car.
Have a Nice Day.
PostPosted: Sun Aug 30, 2009 10:04 pm
I did a blokes cam timing on his new +100 flat top piston 998. Did tune up on another customers B series, helped girlfriend reco front sub frame for ex tas rail moke and fitted some nice new H4's and relay to my mini van! More mini work tomorrow..
PostPosted: Sun Aug 30, 2009 10:46 pm
You must have the only six-doored mini in existence!
You always seem to be re-skinning doors.
PostPosted: Sun Aug 30, 2009 10:47 pm
Pulled the wiper motor and drive to bits, cleaned and greased and now have single speed wipers again that actually work, instead of half speed "intermittent" wipers.
 Post subject: fitted stock flares
PostPosted: Mon Aug 31, 2009 6:24 am
I fitted stock colour matched flares to Percy the van, but found the plastic strip is way short! (the guy I bought the flares from said they would be almost long enough and you could get away with it).
Now I just need new plastic strips, oh and front discs and rear step drums, and cooper S rear slaves.....
Then the flares will be nice and full!
Cool stuff!!
PostPosted: Mon Aug 31, 2009 1:17 pm
Put the door skin on the drivers door.
The frame
The Skin
Lined up and clamped with vice-grips
Taking it slow and easy
Done
And it fits - sort of
Top left corner doesn't quite follow the curve and will need some work - have to do the tack weld to the top corners and there are a few hammer makers imprssions that a judicious application of a thin layer of filler won't fix other than that I'm pleased with a first attempt a 'skinning'
David L
