It is currently Fri Jul 18, 2025 1:53 pm
 Post subject: stupid question I know
PostPosted: Thu Aug 27, 2009 8:18 pm
Hi it's a stupid question I know but when doing a starlet conversion why don’t they us an EP95 AWD starlet and make an AWD Mini. there are a couple of EP95's in Aus but they cant be registered here for some reason so they should be cheap the rear end is just a cart axle style so it would need to be narrowed but powering out of a corner with all 4's smoking would be great. Regards Daren
PostPosted: Mon Aug 31, 2009 8:24 pm
it's been suggested a few times, but no-one has been game yet.
I am very slowly working on an AWD based on a Honda Civic... have a look at www.ringmini.de
PostPosted: Mon Aug 31, 2009 11:47 pm
I think the aprehension is the knowledge and the fabrication skills required to set up the rear suspension. Updating the Mini engine with another up front is relatively straightforward as the overall suspension setup/design can be retained but I'm sure there's much more work involved in the design and fabrication of a suitable rear subframe (or an IRS setup??) that works well and integrated properly for use with an All Wheel Drive system.
I would attempt (and am doing so) the Starlet GT conversion in the front but would baulk at any more than using the standard Mini "building blocks"
-Alan
PostPosted: Tue Sep 01, 2009 9:03 am
Itd be a lot more expensive fabrication wise. And youd need to design and build a rear frame to carry the rear diff as well as mounting everything else. I wouldve done it but ive started a FWD starlet conversion.
Simplify and add lightness
PostPosted: Tue Sep 01, 2009 9:22 am
Also it will be harder to get engineered, because less of the Mini's original suspension and "crossmembers" (subframes) is retained. But I'm sure it can be done.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
