I have some questions regarding fitment of a new radiator. I purchased a new radiator and have measured it against the öriginal"one which I removed.
Now that I am trying to fit the radiator I have some problems.
Either the fan is contacting the radiator OR there is a large gap between shroud and radiator on the Engine side between shroud and radiator.
So my questions are:
Should the spacer in the picture below be fitted?
What should the gaps on either side of radiator / shroud / body of car normally be?
Additionally during the engine install I had problems with the engine stabilising tie rod. It doesn't fit quite right.....and I have tried every combination of fitting it (backwards forward turned around etc) Please comment on the picture below and let me know if this is correct....I am starting to think that this may be having an influence on radiator problem.
Thanks in advance.
