Hi All,
Thought i would jump in and clear things up.
Back when i had the Mini 1000 class up and running i was approached by coleen from respect oils in QLD to try her racing 50 in the minis. When she come down here i had a motor on the dyno using K-Mart Oil. She asked me what oil i was using to run the motors in and what i was using to do testing with. I replied K-Mart's own brand KMX. She was horrified!
She asked me why i was using this oil, i told her because i had found it to be very good, held it's viscosity very good at high temperatures. She then gave me some of her racing 50 oil to try in the mini 1000's. We used the same bearings, camshafts and followers for two and a half years and they were not changed. The only thing changed were the rings every 12months.
After discussing the K-Mart Oil she had it tested for me by the people that blend her oils. She took a K-Mart sample and two other 20w50 oils at the same time in unmarked bottles.
The industrial chemists comments were "where did you get this oil" referring to the K-mart oil. She explained to him that this was a commercially available oil from a supermarket. His comment to that was you cannot produce the additive package that goes into this oil (the K-Mart Oil) as an everyday oil for that price.
He went on to explain that the oil was performance orientated, suitable for turbocharged engines and light diesels. She explained to him that this is also written on the labelling. She then took the oil and tried it in her test taxis. The oil was tested at 2500km, 5000km, 10,000km and i think at 15,000km as well. The Oil came up as an excellent oil every time.
Her comment to me was, i hope you don't tell too many people about this oil! Coleen has now sold the business and it is now called PM Lubricants in QLD. Their racing 50 oil that they produce is second to none as a mineral based oil but very expensive (about $15L). Coleen then checked into who was producing the oil at the time and how they could produce the quality for that price. The answer she got back was when you order 300,000L of Oil at a time you can have what you like in any coloured package! I think it was Mobil that originally blended the oil for them but it has now gone through at least two oil companies since. I think Shell first and now Caltex.
I still continue to use this oil in my road cars and on the dyno for running in and testing eg.BDA Engines running at 9500rpm. We just had a Holden 355 stroker engine on the dyno producing 523HP and 472ft/lb of torque on KMart Oil as well running at temperatures up to 215*F and encounter no problems with the oil at all.
Yes there are probably better oils on the open market but for quality and price i'll always use the K-Mart Oil in road engines.
After checking with 4 oil companies about labelling they all explained to me that if an oil is rated for turbocharged engines it has to be a good quality oil as they would be liable if the oil failed in operation and could be had up for false advertising.
This is what i have found and i am not qualified to analyse oil as probably nobody on here is. All the information i got came from a lab who are qualified to test oils.
P.S When Coleen owned the business nearly all the trucking companies in QLD, buses and taxis where running on respect oil.
Also, with Synthetic oils today they are mainly designed for overhead camshaft engines where the camshaft runs in a bath of oil all the time. When used in dinosaur engines like our minis if will not stick to the camshaft lobes, followers and rockers like the mineral based oils do as its thrown off because it's lacking a key additive that makes the oil stick to components. This is why Castrol originally designed the GP50 oil for larry perkins because they were having rocker gear failure and the oil was not sticking to the roller rockers or the camshaft, this is now known as Castrol Edge 25w50 but i do not know if it is still the same oil (same ingredients) but we still use this in a lot of racing minis with a tube of molybond 2.5 (60g)
http://www.molybond.com.au/index.php?option=com_content&task=view&id=67&Itemid=118
Graham Russell
