It is currently Thu Jul 24, 2025 11:29 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Thu Sep 24, 2009 8:13 pm
well does it engage all of the other gears easily? if so i wouldnt worry about it because im assuming its a 3 syncro box.. they dont like going into first i know i cringe when i select first in mine while the car is still rolling slightly.. its not the easiest thing
Potato
PostPosted: Thu Sep 24, 2009 8:20 pm
its a 4 syncro box, i have not actually driven it further than the end of the driveway, so i will take it for drive up the road on the weekend see how it goes
77 Leyland Clubman
1293cc, LCB extractors, pulsar dizzy (recurved), cooper s disc brakes, 40DCOE Weber
PostPosted: Thu Sep 24, 2009 8:43 pm
72clubman wrote:
i have the tin type master cylinder does that come in both sizes
could it be the slave cylider
Not sure about new tin type ones but the old tin type clutch ones were .75".
It's the BIG plastic cap Oz ones that have both sizes and look the same.. sometimes the size is marked on the body, 1/2 way up.
Slave cylinders are all the same (7/8") but the seal may be leaking air in on the back stroke. Has a similar effect. Common problem...
PostPosted: Sun Sep 27, 2009 4:44 pm
i put the bent clutch leaver in and re bled the clutch MC and it all works now
77 Leyland Clubman
PostPosted: Sun Sep 27, 2009 6:17 pm
So was it the bent arm or the bleeding that fixed it? 8)
PostPosted: Sun Sep 27, 2009 6:23 pm
bit of both bleeding it again allowed me to get it into 1st much better like 60 -70% of the time now the bent arm gives me 90-95% 1st gear engagement first time without selecting another gear first
77 Leyland Clubman
PostPosted: Sun Sep 27, 2009 7:50 pm
Some things to consider
The piston in the slave (with the straight arm) could be hitting the circlip the bent one pushes the piston in further so you could have more travel.
Also ensure you use the correct return spring.
Kiwiinwgtn
Users browsing this forum: Bing [Bot] and 98 guests
