Mick wrote:
This is important.. So the starter motor crashes in with a loud bang bang, but the motor doesn't turn over?...or the starter motor whirrs loudly (ie. the starter motor is spinning) but the motor still doesn't turn over)?
The motor churns over like normal but doesnt fire. Its like when you have a flat battery and cant get it to start... everything turns over OK, but there isnt enough energy to fire into life. Its the same sort of thing... but this time, the battery is strong.... everything cranks over, but there is no firing to life.
I had the same issue before with my Moke and the first time it was one of the leads had jolted loose. The second time there was a fine piece of metal in the carbie that was stopping the piston from working properly.
I have checked the leads and they all seem fine. Distributor cap hasnt gotten wet. Car has over half a tank of fuel. Pump is pumping fuel once reds are on. I checked the inhibitor and that doesnt seem to be the issue (in any gear other than park or neutral, the inhibitor prevents ignition, although at the moment i have ignition, just no engine coming to life). Not being a carbie car, i dont know what to look for in the EFI system.
