It is currently Mon Jul 14, 2025 2:45 am
 Post subject: I'm pulling it
PostPosted: Mon Sep 28, 2009 6:13 pm
I'm going to pull the G13B out of my mini to change some of the seals and repair a hole in the sump. Whilst it's out what other stuff should I change?
At this stage I'm doing the sump seal, the diff seals and the engine mounts.
PostPosted: Mon Sep 28, 2009 6:24 pm
Make sure you've got the best gearbox you can get.
Timing belt?
PostPosted: Mon Sep 28, 2009 6:30 pm
Timing belt / water pump if they are nearly due.
Check how much life you have left in your clutch while you have it all out.
PostPosted: Mon Sep 28, 2009 7:14 pm
fit a turbo :P
PostPosted: Mon Sep 28, 2009 8:54 pm
Thanks for the replies.
Timing belt is an excellent idea. I don't know why I didn't think of that. I was talking today about it with mates at work.
It already has a turbo. T25. I was thinking of downsizing the intercooler. But I know bugger all about injection and turbo cars so I'll leave it for now.
And a water pump too. I have found it really hard to buy spares for the injin. The Suzuki and Holden dealers do everything by VIN code now.. I don't have a suitable VIN code.
