It is currently Fri Aug 01, 2025 9:22 pm
PostPosted: Thu Oct 01, 2009 7:26 pm
Pulling apart a track car atm and buggered if I can find a Voltage reg on it. Its got an alternator not a dynamo, so is it built into the alternator? Its a 72 clubby, but very little standard about it so not sure if its missing or just built into the alt.
Cheers in advance,
miki.
PostPosted: Thu Oct 01, 2009 7:28 pm
What does the alternator look like , does it have a large plastic cover over the back of it ? If so it should be internally regulated (probably not the right term but it has the regulator on board) .
 Post subject: tyvm :)
PostPosted: Thu Oct 01, 2009 7:42 pm
indeed it does. *black plastic rear cover*
Awesome news.
PostPosted: Thu Oct 01, 2009 10:13 pm
The regulator is inside the plastic end cover, it is a tin can with 2 or 3 wires on it. I had to swap mine out recently, got another from a wrecked alternator.
