It is currently Sat Aug 16, 2025 2:15 pm
 Post subject: Indicator Stalk
PostPosted: Fri Oct 09, 2009 10:32 am
Hey,
Yesterday my left indicators stopped working,
i took of the plastic thing around the indicator stalk and this was in the bottom:
It appears to be the little thing that triggers the indicators on and off.... is there a way of fixing it... it looks like it has snapped near where its connected.... or is it time for new one?... if so does any one have second hand ones?
Thanks.
PostPosted: Fri Oct 09, 2009 11:13 am
I didn't see one of them last time I pulled some indicator stalks apart.
How big is it?
(yes i realise its on a post-it so guessing about an inch....what diameter though?
I just can't think of where it's come from. )
PostPosted: Fri Oct 09, 2009 3:20 pm
hmm its hard to explain... there are 2 of them... one for left one for right...
when the indicator stalk pushed up or down, they then connect with a round terminal kind of thing, which makes the indicator come on... its proabbly bout 1mm thick.. if that.
im not good at explaining things, haha
PostPosted: Fri Oct 09, 2009 3:32 pm
The one I pulled apart had a heap of balls and springs inside.
Sorry, I can't help you on this one.
PostPosted: Fri Oct 09, 2009 3:37 pm
I had the same problem with mine, shitty idea i reckon, i rammed in a piece of MIG wire and bent it up, still workin now and its been a few weeks but i would look at getting a new stalk
PostPosted: Fri Oct 09, 2009 4:55 pm
Maybe you could cut a paperclip down to size?
:lol:
PostPosted: Fri Oct 09, 2009 5:21 pm
:lol:
Thats a good idea :idea:
PostPosted: Fri Oct 09, 2009 5:48 pm
Mods rock!
Sorry, I have tried but never found a satisfactory way to fix them. Usually by the time they start doing things like that the whole assembly needs replacing. They really are not that dear new.
PostPosted: Fri Oct 09, 2009 6:53 pm
I agree. Get a new one, it should outlast the car... :lol:
PostPosted: Sat Oct 10, 2009 1:20 am
I agree too why stuff around. If it broke it needed replacing anyway :lol:
PostPosted: Mon Oct 12, 2009 9:39 pm
if you get a new one,
the one's listed on ebay for about 70 bucks are a reproduction item for a series 3 Landrover. i got mine from ebay uk, landed for about 20 bucks....
just a tip.
PostPosted: Wed Oct 14, 2009 7:23 pm
Occassionally they appear on ebay in aus by a seller 'landcrab'. Although they are for other BMC cars, they are the same unit except for the plug connection and these are very easy to replace with the existing one. I got one for my clubbie and luckily for me, he is only a couple of suburbs away and I was able to pick it up.
1964 998 Cooper , 1968 Morris 1100
 Post subject: Indicator switches
PostPosted: Wed Oct 14, 2009 8:00 pm
Convertible Mini sells them too for $90. Mine plug straight in and have headlight flash optional extra. Why send them to buy one somewhere else when an Ausminier sells them ?
"Let us remove your "SHORTS"
PostPosted: Thu Oct 15, 2009 2:58 pm
I'm about to adapt a stalk from a Hyundai, it's not original I know but it reduces the number of switches needed on the dash.
PostPosted: Thu Oct 15, 2009 4:35 pm
I'm thinking the same thing also. and as I drive a Alfa thinking of putting it on the other side also
I'm no purist :lol:
