It is currently Mon Aug 18, 2025 1:10 am
 Post subject: too loud
PostPosted: Sat Oct 10, 2009 8:40 am
Hey guys haven't been around for awhile but anyone who remembers me and my van will know that it was loud. Just finished having it rebuilt and apparently it's now louder!! 2inch through to cannon, yeah real rice i know but the sound grew on me. It's a 1970 panelvan (windows) any idea how loud it's allowed to be? i did a little digging around on RTA but i'm still not sure. Assuming it is to loud what's my best solution?
PostPosted: Sat Oct 10, 2009 8:55 am
I'd nearly reckon the cops will soon let you know how loud it's supposed to be, i'm only guessing but 95 decibals sort of rings a bell ( don't quote me on that ) but i run standard cooper s system on my s and it's bloody loud enough. Don't you find it a pain if you happen to drive it any consderable distance?
Colin.
PostPosted: Sat Oct 10, 2009 9:31 am
In NSW it is 96db at 3000rpm at a distance of 2 metres and an angle of 45deg from tail pipe.
Cheers Pete
PostPosted: Sat Oct 10, 2009 10:15 am
Most of your friendly exhaust shop guys should be able to help you out with a good guess and what to do about reducing it to acceptable levels. :wink:
-James.
Toyota 4EFTE Powered Minivan.
PostPosted: Sat Oct 10, 2009 10:18 am
thank guys. i thought it was a bit higher for pre 1975 or something like 105, but it was running 96ish before rebuild. Yeah it does wear a little thin after a while but i don't generally do long trips in my car. I'm kinda torn between sense and loving the sound.
PostPosted: Sat Oct 10, 2009 11:47 am
When I went through ACT rego in March mine was doing about 109 db, they said that it should be about 94ish. I had a new muffler fitted and it was then doing 95 and rego were happy. I don't know if NSW is the same.
The exhaust shop put a flange and hanger arrangement so that I can bolt a different exhaust on later if I want. I might do it one day as I can't hear the exhaust over the Webber.
PostPosted: Sat Oct 10, 2009 9:21 pm
Yeah it might not be so bad except i have to get a blue slip cause it's been more then three months :(
PostPosted: Sat Oct 10, 2009 9:36 pm
Blue slip is not a big deal these days, it's pretty much just a pink slip with the car's body & engine numbers checked as well.
At least you will get a full 12 months rego, not 12-3 = 9 months for the same 12 months cost... :P
PostPosted: Sat Oct 10, 2009 10:46 pm
good to see you back big josh! it's been a while what took so long!?
PostPosted: Sun Oct 11, 2009 8:59 pm
you know the usual breaks, time, money. Hopefully i'll be issue free for awhile now *fingers crossed* and i'll be seeing you at a few runs.
Users browsing this forum: No registered users and 334 guests
