It is currently Sat Aug 16, 2025 12:07 pm
 Post subject: Wheel cylinder question
PostPosted: Sun Oct 11, 2009 5:00 pm
Are the gaskets that go between the wheel cylinders and the backing plate needed? - What is their purpose?
David L
PostPosted: Sun Oct 11, 2009 5:39 pm
Nice question i'm about to do the same and also the ones i have taken off dont have them
PostPosted: Sun Oct 11, 2009 7:48 pm
Asked this same question not long ago when replacing my front wheel cylinders and found this from Minisport.
http://www.minisport.com.au/prod1525.htm
This gasket is fitted between the backing plate and the wheel cylinder on any model that had 2 front wheel cylinders per side. These are not necessay, but will prevent dirt/dust and water getting in.
I hope this helps. :?
Justin
PostPosted: Sun Oct 11, 2009 8:19 pm
Rear kits came with gaskets, fronts came without. I didn't worry about it -could have cut some out of card but it also makes the circlip a bit tighter. There is a easy tool that can be made up to make getting the circlip on easier.
Dave K.
Users browsing this forum: No registered users and 377 guests
