It is currently Sun Aug 17, 2025 9:34 pm
 Post subject: Nuts!!!
PostPosted: Sun Oct 11, 2009 7:01 pm
Can anyone tell me the length and diameter of mamba/revolution wheel nuts?! Think these maybe pretty close to what i need.
Jellybean nuts are the right diameter @ 12mm but way too short i need about 27mm is give or take a little!
Also on a side note what thread is the mini wheel stud?! All helps with sourcing myself some new nuts for my speedy rims!
Thanks
PostPosted: Sun Oct 11, 2009 7:32 pm
:twisted:
PostPosted: Sun Oct 11, 2009 7:40 pm
Maxx thats not very constructive!
PostPosted: Sun Oct 11, 2009 7:49 pm
:twisted:
PostPosted: Sun Oct 11, 2009 7:50 pm
doesn't really do anything contructive though or help this thread Maxx... unless you actually have any answers!?
PostPosted: Sun Oct 11, 2009 8:15 pm
3/8 thread
Mamba Wheel Nuts
Length top to bottom : 48mm
Length of straight : 33mm
Diameter at narrow section : 14mm
Washer Diameter : 24mm
Washer depth 4mm
Nut / Spanner size 19mm
Is that better ?
PostPosted: Sun Oct 11, 2009 8:17 pm
Dam... too wide and long!
need 12mm diameter and 28mm ish length!
But hey good start to get a lathe on them!!!
PostPosted: Sun Oct 11, 2009 8:18 pm
max :twisted: =jealous :lol: :lol: :lol:
PostPosted: Sun Oct 11, 2009 8:21 pm
Freddo, you missed the pre edited version, i suggested he use those wooden blocks hes so fond of :wink: but i wasnt being "constructive"
 Post subject: Re: Nuts!!!
PostPosted: Sun Oct 11, 2009 8:27 pm
Thanks
The nuts I have for my speedy hotwires are 17.2mm diameter probably clearance for 11/16" and are 19mm long on the stepped part. They also need a washer this should be captive in the wheel but sometimes fall out. The washer is 4mm thick with said 11/16" hole and the outside diameter is tappered from 23.2mm to 21.9mm.
Thread is 3/8UNF
Overall length is 41mm
Hex head 13/16 hex x 22mm long
Hope this helps
4efte powered Clubman
supercharged 998 race car
PostPosted: Sun Oct 11, 2009 10:32 pm
As far as I know, there are at least two types of Revolution wheel nuts.
Here's a pic of the earlier ones. I had to get them made up when the panel shop threaded one of mine. I had four made and used one.
[IMG]http://img.photobucket.com/albums/f357/BoyracerAU/Mini/NewNuts.jpg[/IMG]
The later type are as offered for sale by all the Mini shops. They're no longer tapered.
[Why isn't my pic showing?] :?
Users browsing this forum: stewartp and 318 guests
