It is currently Tue Aug 05, 2025 7:13 pm
PostPosted: Mon Oct 12, 2009 6:52 pm
Hi Matt
I would like a picture
What is the wall thickness off the RHS
Ta
Kiwiinwgtn
PostPosted: Mon Oct 26, 2009 3:20 pm
Hey guys,
I have now removed the input and output shaft nuts and removed the input gear and final drive pinion but i'm not able to remove the big bearings that are fixed into the casing, so how do i go about this this procedure.
Sav
73 Clubman - Working Progress
PostPosted: Mon Nov 09, 2009 7:58 pm
This is the puller i have made from the info on this thread
So simple and easy to use.
Still need to weld the nut on which i will get my mate to do with the tig.
Thanks
Kiwiinwgtn
PostPosted: Mon Nov 09, 2009 9:38 pm
Thats a great invention kiwiinwgtn but how is that supposed to remove the big bearings enclosed in the casing or is it for the input shaft bearing.
Sav
PostPosted: Mon Nov 09, 2009 11:08 pm
First you knock out the input bearing and shaft/1st motion (don't forgett to remove the circlip holding it!) via the main shaft (I used a rubber mallet & a piece of wood to knock it) and then you fit a 'special' tool between 1st gear & main bearing and knock that out - again with the main shaft - in the other direction.
You can see my 'special tool' in the lower right corner of the next picture: It's just a smal block of wood and a bend piece of alu.
Keep an eye on the synchro hubs while you doing it! If you push them too far, they start to spit little springs and balls all over the place :shock: Same if you lift the main shaft out of the box.
Jan
PostPosted: Tue Nov 10, 2009 5:58 pm
ok its for the first motion shaft.
but i do have a bearing remover for the mainshaft bearing which is used as per the diagram from Asphalt.
I also made this one
Kiwiinwgtn
PostPosted: Tue Nov 10, 2009 8:07 pm
I managed to get it out without the special tool - twice - but I guess it would be easier with it - think I just used a piece of wood
David L
PostPosted: Tue Nov 10, 2009 9:40 pm
Its so simple after looking at thoses diagrams and pictures, now i'll simply make one of those spacer things to remove the bearing.
Thanks everyone for the information.
Sav
Users browsing this forum: Bing [Bot] and 89 guests
