GT mowog wrote:
OK thanks, I found it that time - a reference to cavitation leading to erosion / corrosion? That it?
I would have to disagree. The design of the water pumps in minis is that of a centrifigal pump. There are a lot of variables in the design of these pumps and depending upon these variables the optimum shaft speed is between 900 and 3000 RPM. Some can run faster. At slower than optimum speeds the fluid flows at a lower rate. At speeds not far above the pump cavitates. Also, the correct method of shuting off flow from a centrifigal pump is to shut off the outlet to i) ensure that the impeller and seals still have 'head' and ii) to avoid cavitation. This is done in a car engine by way of the Thermostat. Further the ID of the by-pass fitting on the pump is only about 8 to 10 mm and the outlet fitting is about 22 mm. The flow rates between the two are chalk and cheese, not to mention the flow dynamics caused by having the by-pass coming off at hard right angle. Any 'flow' through the by-pass would be very very small indeed.
Regarding the optimum shaft speeds, being probably around 3000 rpm for the mini water pump, this is why we fit larger diameter pulleys on the pump for race motors, because they constainly run at higher rpm it is necessary to slow the pump to prevent cavitation.
I partially agree with this. Running a pump at higher than design speed is not always going to cause cavitation though. It depends on what is on the suction side of the pump. Many pumps can be purchased in 1500rpm (1450rpm) and 3000rpm (2900rpm) speeds but are the same pump. Getting the 1500rpm version and speeding it up won't do anything to the pump. Also, variable speed drives allow a pump to be run at 110% of original speed. It depends a lot on the pump design and the flow path (and the static head on the pump).
Slowing the pump down on race engines may be due to cavitation, but would also be done to reduce the power absorbed by the pump.
Basically cavitation is when the pressure in the pump drops low enough that the water begins to boil. Blocking the suction can cause this, or incorrect pump selection.
You say "Any 'flow' through the by-pass would be very very small indeed.". I work in the water/wastewater industry so I have a fair bit of experience with pipes and pumps and if you do the calcs you often find that putting an orifice plate or partially closing a valve doesn't have a huge effect on flow until you start to get the valve to the last 25% or so of travel. The bypass hose on the Mini may still pass a fair bit of water.
If you run a centrifugal pump with zero flow the radial force on the pump shaft is a lot higher than if there is some flow, so the seals and bearings can wear out quicker. I suspect this wouldn't have a huge impact on pump life for a car water pump though, as they are probably a fairly robust design.
I would probably lean towards leaving the bypass there, since it is there to start with (or drilling the thermostat as the Doc suggests), but it would probably work fine without it and I don't think it would have a huge effect on water pump life. There are more important factors anyway, like making sure you get a decent pump instead of one with a pressed steel impeller.
