It is currently Thu Aug 14, 2025 6:09 pm
PostPosted: Wed Oct 14, 2009 9:51 pm
my rover booster brake pedal box thing i bought of ebay ages ago seems to stick out far in the car looks odd..
can it be adjusted? for less travel.
sits out further by about 3 or 4cms then the clutch peda,l looks really funny.
Im not really sure what it would be like to Drive. :?
PostPosted: Wed Oct 14, 2009 10:05 pm
Get a rover clutch pedal.
:D
The rover pedals were bent 'into the cabin' more.
PostPosted: Wed Oct 14, 2009 10:09 pm
dam it!!!!!
i do have a another pedal box with both on it..
so that means the pedal box & steering rack & crap has to kinda come off?
PostPosted: Wed Oct 14, 2009 10:34 pm
Not steering rack, column maybe.
You could change it over in the car though it is a bit difficult.
The other option you have is to put an early (aussie) brake pedal in and ditch the rover one (this is what I did), however the rover pedal is the far better solution.
If the old pedal is to go in, it will need to have the stiffening rib ground back 2mm or so to clear the brake switch, and the hole for the clevis pin is a different size and needs to be changed.
As I say, canging the clutch pedal is the way to go for you.
:D
PostPosted: Wed Oct 14, 2009 10:38 pm
thanks Harley.. legend.
fun fun job that's going to be. :oops: crap me last time..
will be the same again!
PostPosted: Thu Oct 15, 2009 2:54 pm
it was easy to do, saying that still took a good 45 mins upside down hehe
did not have to take the box out you can do it in the car.
now it looks right!
8)
PostPosted: Thu Oct 15, 2009 3:00 pm
Make sure you modified you gas pedal to suit too.
I was once passenger in a mini that had mixed pedal heights and the driver kept hitting the gas instead of brake because they weren't lifting their foot to the right height.
PostPosted: Thu Oct 15, 2009 3:26 pm
So are you saying I should adjust the pedal or use a rover accelerator pedal?
I have a rover brake and cluth one now.
PostPosted: Thu Oct 15, 2009 3:33 pm
If they arent within a fail safe distance of height to each other, then do whatever you think will give you a better outcome.
I guess on a mini having the acceleratror lower isn't a bad thing, on my rover I'd occasionly press both pedals at once.
It's what you're comfortable with mainly.
Users browsing this forum: No registered users and 260 guests
