It is currently Fri Jun 27, 2025 5:36 am
PostPosted: Mon Mar 14, 2005 12:53 am
just to comment on orange's comments..
For tarmac, stick with 10's but go wide. 13s will affect your handling (+ will add weight)
Boosted 8.4's? Not under 10 inch wheels im afraid. And a booster just is added weight that is not required. Disc brakes are fine without a booster.
Would you still have subframes?? Or chop them up to save weight??
Would you still run an A series engine?
I'd say a clubby shell is too heavy to start with anyway... try an early 850 shell
OH.... and you'll need a snorkel for those water crossings.
PostPosted: Mon Mar 14, 2005 9:01 am
note: i said use 13 and 12 inch wheels, thats y i sed 8.4's, and the booster would allow u to get a little closer to the corner before braking, so in theory it would save u time on the micro second u lost just coz theres 2 extra kilos in the car! and ur missing the point, this is not going to be a super money wrc winner, its a great thing to do just for enjoyment which means, changing the engine$$$$$$$$ i dont recall saying anything about the subframes, but keep the front and put a beam axle on the rear! if u set the car up right 13 inch wheels wont effect the handling enough to cause problems, plus u get much more traction from them, where as with tens they have to spin much faster to cope with the same speeds!
Potato
PostPosted: Mon Mar 14, 2005 9:35 am
for starters i would consider not converting nouns into verbs..
ala
rally-ising
then.... start saving
also, see the thread in the motorsports category, forum, thingo.... ;)
PostPosted: Tue Mar 15, 2005 12:10 am
Hmmm. Couple of things with a brake booster...
1. You will lose the "feel" of the brake pedal. OK for city streets, not for racing.
2. A booster wont increase the braking ability. Its for those girls who cant push the pedal hard enough to lock the brakes. :lol:
2. Reducing weight is a MUCH better way of increasing a vehicles performance. A lighter car will accelerate and brake faster. 2kgs WILL make a difference.
3. A booster is just another thing that can fail. Cmon - it IS a mini afterall.
Also, larger (and possibly heavier) wheels will put extra rolling resistance on the motor, reducing the available power. Dont worry about tyre RPM, worry about the FLYWHEEL rpm :wink:
Im not trying to start an argument here, simply staing facts.
PostPosted: Tue Mar 15, 2005 8:55 pm
OK so how do i get sponsored.
And into rally in the first place.
I'm gonna get as much hills driving experience as i can.
What else?
I"m thinking this should be a road/rally mini, as to supersprint it too.
What body mods are required?
And the big question... where do i get a (good) Morrie shell from (people say not to hack up a good mini like mine- so i wont.)
PostPosted: Thu Mar 17, 2005 8:24 pm
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 29607&rd=1
Go buy this.... 8)
PostPosted: Thu Mar 17, 2005 8:39 pm
No worries :D
Its on the VISA card now :wink:
mini Visa of course! :)
PostPosted: Thu Mar 17, 2005 8:57 pm
as u know ie pt an add in the victorian mini mag for u. dont use ur rally car as a road car, u will find it hard to register it for starters, then u wont be able to equip it to the max... if u know wat i mean, use the clubbie on the road, its all cold and neglected, it needs some love!!! :lol:
Potato
PostPosted: Thu Mar 17, 2005 8:59 pm
When i say road/rally; i mean that it will be used for track use too.
Supersprinting, closed tarmac rally events, etc.
As well as the bush bashing rally
PostPosted: Thu Mar 17, 2005 9:44 pm
ahhhh ok then, no probs then
Potato
