It is currently Sun Aug 03, 2025 7:05 am
 Post subject: Cage /carby question
PostPosted: Tue Oct 20, 2009 7:59 pm
first Question is does any one make a bolt in cage for a clubby?.
2nd question is i have a 1.5" su at the moment , my engine is a mildy worked 1100cc , i am thinking of getting twin 1 and 1/4" twin carbs ,basically would it be worth it , would there be any noticable change in power delivery?.
thanks for any help
PostPosted: Tue Oct 20, 2009 8:41 pm
This space for rent
I replaced the single 1-1/2" SU on my mildly worked 1100 with twin 1-1/4"s, the difference was pretty significant. My cam comes on around 2800rpm and pulls hard from there, but the single carb saw it running out of breath before 5000.
The twins now let the cam do all the talking, it pulls hard everywhere.
PostPosted: Tue Oct 20, 2009 9:02 pm
It`s all in the manifold
PostPosted: Tue Oct 20, 2009 9:06 pm
This space for rent
I'd believe that :shock:
If only I had room back there for a nicer manifold than the standard Cooper S item :cry:
PostPosted: Tue Oct 20, 2009 9:17 pm
hey thats an interesting point,,, I've always been tempted to give one of the maniflow twin carby manifolds a go... you saying they don't fit? Does anyone have any experience with these?
PostPosted: Tue Oct 20, 2009 9:20 pm
This space for rent
I went looking for a second hand one a few months ago without luck, and got talking to David Rosenthal about making one up. With my air filter setup I've got very little clearance to the firewall as it is, and a longer (better) manifold just won't fit in my car. If you've got Ramflo's then it probably would, but someone else can confirm that.
PostPosted: Tue Oct 20, 2009 9:29 pm
I don't use Ramflow's... Can I ask what filter your using? I use the K&N cone filters..
I've thought about making a manifold a few times, I think it could be the way to go..
EDIT----> :idea: someone might correct me here,, but if you have a lack o room for long runners, if your balance pipe is large enough in diametrer it might eliviate the problems accociated with short runners :?:
PostPosted: Tue Oct 20, 2009 9:34 pm
This space for rent
These ones.
They take a Ryco A109 filter and have stubstacks cast into the base plates, very nice 8) Importantly for good flow, the filters are reasonably deep which lends to the space problem :(
PostPosted: Tue Oct 20, 2009 9:37 pm
So youd run a hollow balance pipe? I was under the impression it was just a rod to hold the carbs the right distance apart for the ports.
No air/fuel mixture would go through a balance pipe as gases take the path of least resistance. But im open to correction.
Simplify and add lightness
PostPosted: Tue Oct 20, 2009 9:46 pm
Balance pipe serves 2 purposes -
1. It allows the engine to idle and run reasonably even if the linkage isn't adjusted perfectly.
2. It stops the SU pistons from fluttering (moving up and down). This would/could happen with NO balance pipe, because each carb gets 2 intake strokes in succession then 2 idle strokes. The pistons would tend to fall when there is no suction.
IMO the stock balance pipe is heaps bigger than it needs to be though, and poorly positioned. Aftermarket manifolds flowed better than the stock Cooper ones.
PostPosted: Tue Oct 20, 2009 9:50 pm
So the balance pipe is more to equalise the pressures than to flow air/fuel?
PostPosted: Thu Oct 22, 2009 6:41 pm
cool i think ill the give the twin carbs a go,
so guessing noone makes a a bolt in cage for a clubby????
PostPosted: Thu Oct 22, 2009 6:46 pm
Yes.
Weber/Dellorto manifolds do not have or need one (they have no pistons to flutter up and down).
PostPosted: Thu Oct 22, 2009 7:32 pm
In England, Yes.
Here - not to my knowledge.
I'd still contact Mike re the single as per the PM. You will find the cost of twins properly setup and tuned will be quite high - where's Tiny? :D
PostPosted: Fri Oct 23, 2009 6:22 pm
i think i found a twin setup at a good price kevin , so im hoping that doesnt fall through , othere wise ill chase that single setup.
whos tiny?
