The best place for the by-pass hose on our Aussie minis is to simply take it from the heater outlet (at the back of the head) & then add the other end of it into the top tank of the radiator (& yes that means having some one solder a pipe fitting into the top tank)
But with the original by-pass hose fittings blocked off & this new by-pass hose fitted, then 4 wonderful things happen--> One: you don`t blow/split by-pass hoses ever again & if youve even replaced a std by-pass hose before i`m pretty sure you will love me for suggesting this mod
two: you get a wonderful more "EVEN" heat distribution across the entire length of the head, far better for all things runing smooth & reliable
three: when you`re stuck in a traffic jam , in 33deg heat day, & it`s going to pop it`s head off just sitting there idling away, hardly any water moving on idle, hardly any air moving through the rad cause it`s idling , & then what-ever air there is moving is damn hot air,,, so having "HOT" water taken from the back of the head (hotest point) & having it cooled through the rad is an absolute blessing
four: instant lack of cavitation as the whole system actually flow more easilly
If anyone now trys to sugges tthat the engine will take too long to warm up,,, well 5mins is too long is it?
don`t argue with me ok??? it`s the only way to go in my books & you can retain your thermostat for correct regulation of temp,,, as it`s meant to be.
blanking sleaves were "originally" invented to help stop a thermostat failure while racing,,, not so much to regulate temp,,, cause the hole size in the blanking plate would have to be able to become smaller or larger """IF""" it were to be able to regulat the temps correctly across a whole wide spectrum of driving conditions,,, where as a race car is generally running flat out, so a "certain" sized hole is the right regulatiopn for that engine speed & """ALSO""" because there is no thermostat fited , well it can`t fail then can it??? If it got stick shut then your race is over
get it?
& remember,,, No arguing!!!!!!!!!!!!!!!!! If you dis-agree with me on this, then no matter what you say---> I won`t believe it
(unless it makes more sense)
