Okay this build was looking like it was nearing its goal. However I had made a couple of extremely stupid mistakes and it was about time I found them. Fill test radiator-fit to car.. mmm no way mmm rig up some elbow turns.. oh thats it.. yah a couple more oh cool *doesnt notice block entrance tube now higher than head exit* I only ran it for a few seconds hear and there.. something didnt feel right.. checked rad flow.. NO FLOW YOU IDIOT. Quick turn it off, mm ign doesnt kill it.. okay hit isolation switch gah still running *YOU HARD WIRED THE ALTERNATOR TO THE POWER FUSE MAIN SUPPLY IDIOT* pull fuse with finger *ouch thats hot IDIOT*
Still could have been worse I might not have checked the flow untill after its cooked. Oh and that bit of fuel hose I temp rigged that had the razor slice in it could have pissed fuel over a spark instead of the rocker cover... yes.. idiot. But then I guess thats why we test things, to find the idiot factor and fix them before we embaress ourselves infront of others. But for some reason I thought I would give you all a laugh at my expense
miki
