Been having some brake fade problems lately so I replaced the pads with EBC Green Stuff pads. Brakes are now good.
Bad news is the old pads, only about a quarter worn, had started to wear in a tapered manner. This is bad as it causes the pistons to tilt in the caliper bore when the brakes are applied and I wonder if this is the cause of the brake fade.
Several years ago, but not many miles ago, I overhauled the calipers and fitted new stainless steel pistons that I had had on the shelf for many years.
The new pistons didn't have the relieved area on the face that contacts the pad and I wondered if this was necessary and was told at the time it didn't matter but it appears it does. A bit of research in the recesses of my brain dredged up some old info I had forgotten about. I'm claiming a senior moment here.
I checked some old original genuine caliper pistons (Never throw anything out) and they have a 0.015" relief around about a third of the piston circumference that contacts the pad. The pistons have to be installed with the relief at the top when the caliper is bolted into position.
The relieved area is there to prevent the pads wearing in a tapered manner due to the self energising effect pulling the leading edge of the pad into contact with disc. Its the same principle used in drum brakes to pull the leading brake shoe into contact with the drum. Good for drum brakes but bad for disc brakes.
So my questions are:
Has anybody else experienced a similar problem or is it only me?
Do replacement pistons you have used have the relieved section?
Regards
RonR
Edit: spelling mistake
