It is currently Sun Aug 10, 2025 4:05 pm
PostPosted: Sun Nov 01, 2009 9:28 am
Hi everyone,
I recently posted about how my H4 carby's idle was being set by the choke, but I've got some new problems now.
After setting the idle without the choke, I attempted to adjust the mixture, using the piston lifter thing as a guide. I've read that when the piston is lifted a little, the revs should increase and then go back to normal.
At first, every time I raised the piston, the engine almost died, so I tuned it until it didn't, and found that I was pouring fuel out the exhaust. I'm suprised it even idled - it was running extremely rich.
So I've set the mixture to where I think it should be - no wet soot coming out of the exhaust any more. But how much should the choke raise the revs when out?
If I pull the choke all the way out, the engine jumps over 3000 rpm. That's not right! Am I still running excessively rich? And why doesn't the piston raising method work?
Judging by how it was set up when I got it, I wouldn't be suprised if the actual carby's been set up wrong - any ideas what it could be?
Thanks in advance.
