It is currently Fri Jul 18, 2025 10:47 am
 Post subject: fuel/air ratio meter etc
PostPosted: Fri Mar 11, 2005 10:04 pm
After the dyno day when nearly everybody had dodgy mixtures, I thought it would be a good idea to have one installed.
I think Jaycar have kits- anybody built one, do they work good? :?
PostPosted: Fri Mar 11, 2005 10:12 pm
I bought a kit from Dick Smith, I am half way through building it (and have been for three years!) It looks good with a digital display and I am sure it will look much better when I finish it!
PostPosted: Fri Mar 11, 2005 11:07 pm
Got one, still havnt put it together...
Jaycar Led-Bar one.....
need a sensor yet.......
Oh, and to get a nut put into my dump pipe.....
but yea, a good idea methinks!
J
PostPosted: Sat Mar 12, 2005 6:14 am
J
What about put a sniffer up the tailpipe instead? For testing anyhow..
PostPosted: Sat Mar 12, 2005 10:54 am
All the kits from Jaycar or DSE seem to be for EFI cars. Do they work on non-efi cars? Could be just because non-efi cars do not have an EGO (its more attitude than ego :D).
Is it then just a case of getting a sniffer up the pipe as doc suggests? Could probably get a sensor from a wreck, build a pipe with the senor to shove up the pipe, and bob's your uncle.
Found an interesting article while doing some investigating - http://www.siliconchip.com.au/cms/A_101150/article.html
67 S
PostPosted: Sat Mar 12, 2005 12:14 pm
how does monitoring the tail pipe or exhaust gases (CO2, CO, C, O2, H2O)
measure the fuel : air mixture (C8H18, O2)
intuitively i wouldve though you needed to sense the mixture before it is burnt, somewhere between the carby needle and valves
Inconspicuously Conspicuous
PostPosted: Sat Mar 12, 2005 4:09 pm
I have got a portable gas analyser that runs off the battery and the samples at the tail pipe. All analysers used the tail pipe method before EFI and O2 sensors. I bought mine from Unipart many years ago. A pair of vacuum gauges is good idea also. Unless an O2 sensor is used the lag in readings is pretty bad. A few links....
http://www.pauter.com/super_pro.htm an interesting read. I might do something similar
http://www.mainlineauto.com.au/products ... ..explains lambda values and stuff like that.
I am bored after my operation so I did a bit of research. It's bloody awkward typing with one finger on one hand. The other one is in a sling for six weeks.
Chris
Everything I like is either
PostPosted: Sat Mar 12, 2005 4:51 pm
answered my question: measured left over O2 in exhaust gases that was not burnt with fuel
Chris why were you operated on
hope it wasnt to do anything with doing up nuts
PostPosted: Sat Mar 12, 2005 7:16 pm
Very droll. I have had a rotater cuff injury in my shoulder repaired. 2 hours work and $5,500 for the medical profession. I'm in the wrong job.
Chris
PostPosted: Sat Mar 12, 2005 8:20 pm
rotator cuff tendon repair?
how serious is it, because that in itself is rather concerning
PostPosted: Sat Mar 12, 2005 9:30 pm
Last time I looked at doing this, the EGO sensor had to operate at 600 deg C. Which means pretty close to the engine. Have things changed?
PostPosted: Sat Mar 12, 2005 10:04 pm
This may well be true, but I think many sensors have a heater built in? Otherwise how would the dyno ones work, shoved up the tailpipe..
PostPosted: Sat Mar 12, 2005 10:09 pm
Nissans use a 3-wire sensor....
1 for EGO, the other two for the heater !
J
PostPosted: Mon Mar 14, 2005 7:26 pm
Had a talk to an auto elec today, he said to use the one from Jaycar you also need a air flow meter (the senser in the air box of later type cars).
So it is just about impossible to get one of these to work correctly on a carbed mini.
Cheers Pete
PostPosted: Mon Mar 14, 2005 7:31 pm
Taken from Jaycar's site-
STOCK-CODE: KA1758 RRP: $19.95
Qty 1+ $19.95 Qty 5+ $17.70
Exhaust Gas Oxygen Tester Kit
An EGO sensor monitors your engines exhaust and tells the EFI computer if your engine is running lean, balanced or rich - basically telling the computer if your engine is running in tune. This simple circuit is connected to the EGO sensor, engine block and battery positive and will save you $$$ on tuning by indicating the air/fuel mixture. You can then adjust the EFI computer or tune your carburettor (an EGO can be adapted to carb engines). - Sensor required - available from most automotive stores.
- PCB, silk-screened case, clips and components supplied.
