It is currently Wed Jul 30, 2025 12:21 pm
 Post subject: A quick question.
PostPosted: Mon Nov 02, 2009 5:46 pm
Tomboss Breweros
I'm fixing the busted head gasket on my 1100.
It has bolts, not studs, what is the reccomended torque people?
Thanks in advance :wink:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Mon Nov 02, 2009 5:47 pm
Head studs 42 ft/lb, Rocker shafts 26ft/lb........what head gasket are you using Tombo :?:
PostPosted: Mon Nov 02, 2009 5:49 pm
The recommended thing is to throw the bolts away and fit studs.
The bolts were only used for a couple of years and are not very reliable. They usually break shortly after changing a head gasket. :lol:
PostPosted: Mon Nov 02, 2009 7:58 pm
Tomboss Breweros
Yeah i know the studs are 42 but the coarser thread of the bolts requires a stronger torque to create the same clamping force, IMO
I have been using the silver tin/graphite type gaskets, but i seem to have problems with them. I'm using a monotorque this time.
I have only had a stud break once, got itself right out of the engine and went missing :?
So no one can tell me the recommended torque???? :(
kimini wrote:
Jimmyinamini wrote:
PostPosted: Mon Nov 02, 2009 8:12 pm
According to the Morris 1300 workshop manual the correct tension for the head bolts is 50lbs/ft.
PostPosted: Mon Nov 02, 2009 8:24 pm
Scott did tell you and he is right your theory about clamping pressures is wrong the tension sets the clamping pressure not the type of thread
PostPosted: Mon Nov 02, 2009 8:29 pm
Make sure you start a thread about how you should drive the engine just after you get it all running again with the head gasket.
And is it a copper head gasket? :o :o
PostPosted: Mon Nov 02, 2009 8:32 pm
I hope so. :D
Ok boys!!... I think we have had ample fun with both these subjects. :D :D
PostPosted: Mon Nov 02, 2009 10:02 pm
hee hee hee hee
40ftlbs for the small bores ,,, well that`s what id do,,, & i run it up for quite afew minutes without water & get it up to temp,,, let it sit all night,,, re-torque it dead cold in the morning, re-adjust rockers, (or at least check them), fill with water , Burp it,,, then fang the crapper out of it & Bob`s your Aunty,,, or was that "Bert"
ok sorry, wasn`t funny :-)
hee hee
PostPosted: Mon Nov 02, 2009 11:14 pm
Are copper head gaskets superior to other types?
PostPosted: Tue Nov 03, 2009 9:29 am
why are you thinking of changing your username to copperheadgasket :roll:
PostPosted: Tue Nov 03, 2009 9:51 am
Well no... with all the banter about copper headgaskets I thought maybe I should be changing mine. It's all the rage isn't it?
PostPosted: Tue Nov 03, 2009 10:27 am
Have a read !
http://www.goodvibesracing.com/Copper_Gasket_Tech.htm
They dont mention it but they have to be annealed to work properly and I,ve been told there is art to doing it properly and that is why most people are happy to use the off the shelf ones.
PostPosted: Tue Nov 03, 2009 11:15 am
Oh crap,,, is this still going :roll: :lol:
Alrighty, its my fault that there is al this "banter" about copper head gaskets. There was a thread a while ago, a bunch of people (everyone on here) said they "blow so hell no" and I said I've always used em on my motors with out issue.
So after everyone tried to convience me I was mad, and a few experts got involved and tried to tell me I was seeing things I went and started some research (I know I know,, pretty bad bit of OCD there :) )
Heres what I have found so far;
There are 3 main manufactures of copper head gaskets for A series motors, Payen, Rover and I forget the third but if you really want to know I'll find out and put it up. Now at least one of these guys ""claims"" to have a different type of composite... its my bet that I was just lucky enough to be buying them from one of the manufactures that have a combo that works. ***** BUT***** After reading everyones testimony that they "don't work" I personally am not going to risk it anymore and the motors I do from now on I am going to use BK450's...
Now there are probably a couple of you out there who knew this but BK450 does not always mean ""metro turbo gasket"" the bastards that make these gaskets thought it would be halarious to use the same part number for multiple products. The standard one which has a 4cc compressed volume and the turbo one has a 3.1cc compressed volume.. Maybe some one can explain that, I don't get it. I thought that the turbo gasket might have held more so that it also had so de compressing capabilities as a posed to jacked the comp ratio up?
So there you go... the ""Copper Head Gasket Guy"" doesn't use em any more either :lol:
