It is currently Mon Jul 28, 2025 4:05 pm
PostPosted: Tue Nov 03, 2009 7:33 pm
Accelerator bolt bracket that guids the Accelerator cable on twin su's I'm after that screws
size into the manifold.
I need size and length thanks :)
They are 1 1/4 twins
PostPosted: Tue Nov 03, 2009 7:38 pm
1/4" x 3/4 long UNC.
Use a washer however, its a short blind hole.
PostPosted: Tue Nov 03, 2009 7:41 pm
Is there any difference between auz and english mainifolds?
PostPosted: Tue Nov 03, 2009 7:45 pm
unsure, the thread I checked on my spare (cracked) stock BMC manifold had UNC. As it is botling a bracket onto aluminium, I wouldn't expect them to use anything other than UNC, as UNF will pull the fine thread out of the soft allow to easily.
PostPosted: Tue Nov 03, 2009 7:51 pm
I could buy both if the bolt shop sells them.
PostPosted: Tue Nov 03, 2009 8:06 pm
I think it might be a rover manifold? Any difference.
I just don't have any bolts that fit.
Can you tell me what that bolt is call might be able to check on mini spares.
PostPosted: Tue Nov 03, 2009 8:56 pm
You will get them off the bolt rack at supercrap/ autobarn etc.
I believe it will be UNC if it is ally, but by all means get a UNF equivalent if you need to be sure. No need to import it.
Users browsing this forum: Aussie Brian and 81 guests
