It is currently Sat Aug 02, 2025 5:08 am
 Post subject: 997 or something else?
PostPosted: Mon Nov 09, 2009 9:36 pm
Im just trying to identify an engine i have sitting in my workshop, any advice i can get would be helpful.
The block has very few markings except a 12a497 on the side with a stamped number 1015/5164 on the top face,
The head has no markings were they should be except a ECAM4004 on one end and up near the waterpump end it has 4 C7 or a 4 G7 that i couldnt quite make out, this didnt match up with any book or online reference.
I then measured the bore it was 62.45ish with the vernier and the stroke was 81.5 also with vernier so might be a few thou off, this matches up with a early 997cc cooper.
is there any other marks or identification i can look for?
Any help with this mystery would be most appreciated
John
PostPosted: Mon Nov 09, 2009 9:55 pm
This space for rent
I believe the 12a497 casting was common to all smallbores, 997 to 1098. Can anyone else confirm that?
A 1015/ series engine number is a late Oz 1098, up until circa-1975.
I think the CAM4004 was the smog head fitted to 998's?
PostPosted: Tue Nov 10, 2009 6:52 pm
Simon is correct... ^^^
:wink:
It could have a 997 Cooper crank in it if that stroke is correct.
They are pretty much a 1098 crank dimensionally with slightly less stroke. No stronger, or weaker. Just rarer....
Unless that smog head has been well worked over with big valves, it will go better with a 12G202 (1098) head or better still a 12G295 (cooper 998) one.
PostPosted: Wed Nov 11, 2009 2:46 pm
does motor have fuel pump
PostPosted: Wed Nov 11, 2009 10:44 pm
Possibly, there are a lot of bits with it in boxes, ill have to see what one looks like and go hunt for it
PostPosted: Thu Nov 12, 2009 11:43 am
Goldbrocade means does the block have a hole for a mechanical pump, or is the pump still bolted onto the back of the block?
:D
Sir Alec! we are not worthy!
