It is currently Sat Aug 02, 2025 1:38 pm
PostPosted: Mon Nov 09, 2009 1:35 pm
hello can i put 1100 disc brakes of a morris 1100 on my clubyvan.
PostPosted: Mon Nov 09, 2009 2:01 pm
This Q comes up all the time.
Short answer is NO... not really.
PostPosted: Mon Nov 09, 2009 4:32 pm
is there any way to put them on.
how come they dont fit or go on
PostPosted: Mon Nov 09, 2009 4:43 pm
They are much taller between the ball joints. If you do manage to fit them between the wishbones it stuffs the geometry up that much that they are useless.
PostPosted: Mon Nov 09, 2009 4:56 pm
thank you no worris got stung again got told they will fit straight on now what to do with them
PostPosted: Mon Nov 09, 2009 5:10 pm
Send them back to the seller for a refund.
 Post subject: 1100 discs
PostPosted: Mon Nov 09, 2009 7:57 pm
You can convert them to fit with a bit of work, the calipers will only fit 12" or 13" wheels a lot of them were used on mokes, cheap conversion when the 8-4 discs were not available as they are now.
is it wort the effort NO.
Les
Alpine Mountains full of Mini's and Moke's.
PostPosted: Tue Nov 10, 2009 6:12 pm
i have a complete front cut of an 1100 my local mini mech
said he could get it all sweet set up working for $250 on my little van so all up i can can have a disc brake set up brought and put on for $400 is it worth it or should i just fork out the $1000 for a real mini set cos i will have to get bigger wheels .
PostPosted: Tue Nov 10, 2009 6:22 pm
Are you serious ! If your keen on using the motor just mount it on a proper Mini front subframe and just use standard drums , use the money you would waste on 7.5 disks on getting the motor sorted.
PostPosted: Tue Nov 10, 2009 6:26 pm
I would save your money and go buy some proper Mini ones. 7.5" for 10" wheels, or 8.4s for bigger ones.
Yes I have seen 1100 brakes butchered to `work' on a Mini, but these days IMO it's a waste of time and $$$.
If they bugger up your suspension geometry or fail when you need them, you will not be a happy chappy. :lol:
PostPosted: Tue Nov 10, 2009 6:45 pm
no worris ill stick to the real mini disc save any hasell
thanks guys
