It is currently Fri Jul 18, 2025 12:44 pm
Post new topic Reply to topic  [ 452 posts ]  Go to page Previous  1 ... 27, 28, 29, 30, 31  Next
PostPosted: Tue Mar 15, 2005 11:50 am
Volodkovich wrote:
Im guessing the backs wouldnt nearly have as much load on them so the standard wheel bearings will do for the moment?
Yep, your right. standard rear wheel bearings to SFA ;)
PostPosted: Tue Mar 15, 2005 12:41 pm
Beau wrote:
Hey Doc-
I had another very important question that has not been brought up. When you machine the dick to 65mm, and the hub to 65mm, you lose the hub-centric ring tha's on the hub. Does this affect anything? By removing that ring, the wheel now becomes lug-centric, meaning the lugs are hwta centers the wheels.
Just something I was thinking about while writing and researching.
dont machine your dick whatever you do.. its not worth it
jokes aside.. your wheel doesnt touch the hub your machining anyway.. (thats why they're tapered wheel nuts)
the drum goes over the hub..
when you machine the disc and the hub.. it uses the hub to centralise the disc.. as the hub used to do before for the drum..
the wheel is/always has been centralised by the wheel nuts
Expert in training
PostPosted: Tue Mar 15, 2005 3:55 pm
Hahahaha :lol: , I really need to proofread after I type. I'm lazy though!
You are right. There isn't one on the front. I was looking at the rear hub, where there was a small one, but I don't think it did anything.
Thanks :D
PostPosted: Fri Apr 06, 2007 12:27 am
Instead of reading thru the 30 pages, i'll just ask.....
Who can make the caliper bracket for me, and how much for 2 pairs of brackets (including postage to Adelaide if interstate)?? Anybody on Ausmini?
PostPosted: Fri Apr 06, 2007 1:13 am
Do you want the civic or the accord backing plate?
I am currently looking into other types of braking upgrades including pulsar along with the honda's. and hoping to get them together soon. But don't hold your breth I am doing it in spare time that I DONT really have
and a few conversions:
13B Extend in a 1600
PostPosted: Fri Apr 06, 2007 1:18 am
Ive got solid discs here.... so yeah those. Cant remember the part numbers though, all my info was lost when Ausmini crashed last year.
Hopefully I wont find a vented set lying around in a wreckers somewhere.... :twisted:
PostPosted: Fri Apr 06, 2007 12:40 pm
what are the brakes off and do you want to run 10's or 12's
PostPosted: Fri Apr 06, 2007 12:56 pm
Discs are 'DBA 191' solid, to suit the late 80's Civic.
Would like a set to sqeeze under 10's by machining them down to 7.5", but am happy to get 4 brackets made to suit an unmodified 9.1" disc. I have both 10x7 and 13x7 wheels......
If I get regular 9.1" brackets, I can use them as templates for 7.5" version at a later date.
PostPosted: Wed Apr 11, 2007 4:51 pm
I don't believe any amount of hacking is safe and wouldn't recommend these under 10's.
These require machining and come material removed from the caliper, and a different bracket for the 10's and IMO that's just not cricket.
Brakes are too important to be weakening
 Post subject: Less Kgs
PostPosted: Wed Apr 11, 2007 7:34 pm
Hugh, to be objective, reducing the diameter of disk brakes for use in a more under-stressed application may not necessarily be "weakening" the over-engineered, built-in safety margin of the original items :?:
I agree. I used to do them for 10s but don't anymore.
To fit to 10s you need a different bracket, trim both pads, trim pad bracket, linish caliper a bit, machine discs to 7.9".
By the time you are done, no engineer would touch it, IMO.
Stick with 12" wheels, and stocko 9.1" Honda rotors. They stop real good. 8)
 Post subject: Re: Less Kgs
PostPosted: Wed Apr 11, 2007 11:21 pm
are you going to tell me to what saftey factor they were engineered. Engineering can only take into account best case senario's on materials
a minute hairline fracture or an imperfection in the casting (quite common) the saftey factor is reduced
would you take the risk with your life and your insurance? If you DON'T answer yes then I think you need to think about it really hard.
Nothing personal Mick, I would only like 'safe' modifications when it comes to brakes
PostPosted: Thu Apr 12, 2007 12:53 am
well, since i dont plan on insuring the minis, or getting them engineered.......
PostPosted: Sat Apr 14, 2007 11:06 am
I got some vented accord ones from the wreckers yesterday... I'm gonna try getting them under 10"s
PostPosted: Tue Jul 21, 2009 4:33 pm
Back from the dead
So, I have a set of the Mini Clinic vented Camira disc assemblies with VB Commodore calipers - they just fit under 13x7" Revolutions.
Perfect for their intended application.
Now I was wondering for a 10" application, which small 10-15 y.o. asian car has suitable discs and alloy calipers? Preferably with matching rear discs, as much for weight saving as for braking. These Honda models are now getting on to 25-30 years old too.
Users browsing this forum: No registered users and 23 guests
