It is currently Thu Aug 07, 2025 6:45 pm
 Post subject: Radiator Cap
PostPosted: Mon Nov 16, 2009 1:11 pm
OK the search function returned nothing.
I'm putting a plastic recovery system on the Mini. The guy at Supercheap said my existing radiator cap will be fine. I know that is crap. So I went to REPCO and they gave me RC64-13 replaces CPC 508-13. When I googled the CPC 508-13 it says it has the short 22mm cap. I thought I would need a 27mm cap?
Ideas please, once and for all.
PostPosted: Mon Nov 16, 2009 1:20 pm
Tomboss Breweros
I just put on a new long cap CPC 517-13 by memory, they however are not a proper recovery cap.
Just looked in our tridon book, the recovery cap it claims fits a mini (72-83) is CA4313.
Hope that helps.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Mon Nov 16, 2009 2:58 pm
Hi I just put recovery as well and I put 537-14 (I have aircon)
PostPosted: Mon Nov 16, 2009 3:01 pm
Guys, This is all just theory from what I have read, but......
this is how I believe it works.
You, put a blanking cap on the radiator and then, you need a cap that its suitable for your overflow tank.
I bet I got that wrong! :lol:
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Mon Nov 16, 2009 3:24 pm
This space for rent
That's right if the overflow tank is pressurised.
If the overflow is not pressurised, you still need a pressure cap on the radiator, but one which allows the fluid back into the radiator as it cools and contracts.
PostPosted: Mon Nov 16, 2009 4:22 pm
Thanks for clearing that up for me SGC, I didn't realise that there were non pressurised tanks available.
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Mon Nov 16, 2009 4:25 pm
Look under the bonnet of any car made in the last 20 years. :lol:
PostPosted: Mon Nov 16, 2009 4:29 pm
This space for rent
Yep, it's one less pressurised vessel/hose to fail..
PostPosted: Mon Nov 16, 2009 4:37 pm
Good point Morris ......Very good point.....My brain isn't in gear!
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Mon Nov 16, 2009 6:26 pm
You can not buy a recovery type long neck cap...
Best thing to do is to pull the radiator out and take to your local rad shop and have them fit a short neck to it.
Mine needs to be done at the next engine out.
Minimad
You can take the boy out of the racer.........but not the racer out of the boy!
PostPosted: Mon Nov 16, 2009 8:40 pm
Craig (Minimad) is correct.
Dad took the radiator to the local Natrad and they said the same. I now have a short neck put on the top tank with a Commodore cap so it can be used with a non presurised overflow tank. If I want to use a Morris 1100/Moke etc etc brass presurised tank I can just chuck on a flat cap. :)
Thanks for the replies
