mini50man wrote:
According to some dude on the mini2 forum if you lower the window using the switch, open the door then with the door open raise the window using the switch and hold the switch in the up position for 5 seconds after the window has reached the upper limit it will reset the sensor etc.
Tell that dude on the mini2 forum he's a genius.
I did as you described, and at first the result was the window didn't drop a second time if you closed and opened the door again, just stayed in the normal 4 or 5mm dropped postion, still catching the rubber seal. Miracle. Thought, hey, there might be something in this.
So I did the process again, and varied the way a couple of times by dropping the window with the door closed, opened etc, each method holding the switch for a few seconds and voila, it's back to almost normal!!!!!!!!!!!!!!
Only thing now is it drops about 15mm, but then goes back up again - this is a good thing, but if it fails to go back up again it will be a bad thing as it will let weather in (when it only drops 4 or 5 mm it is still enough to almost seal it properly against the rubber). But if that happens I'll try some more variants of the method and see how I go.
Thanks fellas!
PS I really do prefer my old mini - never have to worry about this stuff......
