It is currently Fri Aug 15, 2025 6:39 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 98, 99, 100, 101, 102, 103, 104 ... 568  Next
PostPosted: Sat Nov 14, 2009 10:37 pm
Finished splicing the Rover column into the Moke. Discovered a radiator leak at the overflow pipe. :(
Talked crap with Mick as his wife clucked over my 10 day old daughter. :)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Sun Nov 15, 2009 10:58 am
My mate brought his Morris 850/Cooper S around, it was running like a hairy goat. Missing, farting, flat spots... He blamed the Dellorto 45 carby on it.
Actual problem was, he had recently fitted new points, and gapped them to about .035" (guess). And the dizzy shaft bushes are worn too.
I closed them up to .015", it runs OK now.
Similar hairy running happens if they get nearly closed up...
:wink:
We can see a recurved Nissan Pulsar dizzy in this car's future. 8)
Last edited by drmini in aust on Sun Nov 15, 2009 1:52 pm, edited 1 time in total.
PostPosted: Sun Nov 15, 2009 11:44 am
fired up the LS and drove it 30 feet around thebackyard. It hasn't been started for 2months and was hiding in the long grass that I have been mowing all ^&**()()ing weekend !!!
PostPosted: Sun Nov 15, 2009 1:03 pm
This space for rent
Chased down the last leaks in the new zorst and sealed them with a little Permatex red silicone gasket material. No puff-puff any more :)
Noticed the coil has made a couple of bids for freedom from its bracket, so found a bolt the right size to pinch it closed, ground out the holes to slots so the coil clears, and nipped it all up tight. Ain't going nowhere now 8)
Gave the e-tag a squirt of black paint, I hate seeing the ugly white wart on the windscreen. Don't know it's there now :D
PostPosted: Sun Nov 15, 2009 7:29 pm
almost finished the wiring for the lights today on Marcia, just have to find a spot for the earths. Also water blasted the drive way so the oil stains stand out amazing how driveways can look white 8) :lol:
 Post subject: stuffed up!
PostPosted: Mon Nov 16, 2009 10:14 am
So I've been working on my A+ auto, and moding the subframe to fit my Moke.
Early this morning I was confident to put it in, I have taken my time with the subframe, auto engine mounts, CVs (who knew the inside pot joints didn't fit through the hole in the subframe? Guess that bit of learning comes from getting a 'running engine unit' in bits... :? I was so proud of my CVs and shaft all tidy on the bench, then had to stuff around though the subframe...) cooling system mix of A series Moke and A+ confusion...
Any way long story so far huh!?
So during the building phase on the bench I made a couple of wooden blocks to stop the subframe dancing around, few Tek screws presto.
BUT some twit forgot to undue the rear screws holding the bits of wood underneath the back tips of the subframe (hey it was an early start Ok!) any way, the whole lots fits great, except now I need to crawl underneath and work out how to remove the screws, heads won't go through the bolt holes into the cabin, so I'm thinking destroy the wood, cut the screws and slip them out. I don't really want to lift it off again.....
Ok so thats as far as I got, off to work laughing at myself all day.....
Cool stuff!!
PostPosted: Mon Nov 16, 2009 1:20 pm
Painted some brushable tar onto wheel arch side of the welds (after painting cold gal paint the other day)
Finished the A panel - discovered the bottom hinge doesn't sit straight (in line with the side of the car but points into the car a bit :evil: )
David L
PostPosted: Mon Nov 16, 2009 9:48 pm
Took the windows out, the doors off and the plate covering the heater hole, with a little help from my grinder.
Sent my car off to be soda blasted, some new panels and painted!
PostPosted: Mon Nov 16, 2009 10:05 pm
Pulled the float bowl lid off and cleaned everything with degreaser and elbow grease. (Ran out of carby cleaner, always run out of the one can I need!). Also cleaned the gasket (getting on) and screws and reattached.
No more leaks! Though I'll wait a week before calling my hunt for all engine bay smells a success.
Took it for a ride, filled up with gas and realized I left my wallet at home AGAIN :roll: The servo guys are used to the dopey mini driver now, so wasted some precious 98 going home to get it.
Now getting the urge to do more tuning. To the hinderance of my job searching and other work. Need to gap the plugs, and do valve clearances. Itching to try my hand at playing with timing but I'll have to wait till I can buy a colortune (to check carby is properly setup) and a timing light.
Copper 4 lyfe!
PostPosted: Mon Nov 16, 2009 10:46 pm
wired in the new digital tacho (acewell 1500).
still trying to get the drum brake off so i can install the reed switch for speed pickup.
1965 Morris Mini Deluxe - 998cc SC12
PostPosted: Wed Nov 18, 2009 12:48 am
Well I found out that the steel bodies from old washing machines make great replacement metal for panel repairs. Fixed a few rust holes in the floor of my mini and underneath the sill panel. Which made a much better repair than the bodgy one the last owner did...
PostPosted: Wed Nov 18, 2009 12:29 pm
dropped the crank off at spiro's for motor no2
PostPosted: Wed Nov 18, 2009 2:56 pm
MiniKit wrote:
Well I found out that the steel bodies from old washing machines make great replacement metal for panel repairs. .
Also old computer cases :wink:
David L
PostPosted: Thu Nov 19, 2009 6:15 pm
i dropped out the rear subframe out of our 65 deluxe....the hydrolastic fluid had the colour and consistency of gravox...didnt smell as good
PostPosted: Thu Nov 19, 2009 7:26 pm
as my car has been left outside in the sun for a week and with today being 43 degres here in adelaide i decided to cook up some bacon and egs on the roof :shock:
Users browsing this forum: No registered users and 214 guests
