It is currently Mon Aug 04, 2025 3:13 pm
 Post subject: A+ diff ratios
PostPosted: Tue Nov 17, 2009 6:25 pm
Hi
Will an A+ crown and pinion fit a non a plus box (rod change)
Ta
Kiwiinwgtn
PostPosted: Tue Nov 17, 2009 6:31 pm
Yes.
The only problem you will have with the taller ratios is the bigger diameter pinion will foul inside the bearing retainer.
Simply put the retainer in a lathe and bore it out to clear.
Yes :D
Have a Nice Day.
PostPosted: Tue Nov 17, 2009 6:38 pm
Hi Kev
Not sure what you mean by bearing retainer
Ta
Kiwiinwgtn
PostPosted: Tue Nov 17, 2009 6:41 pm
The big cast steel thing (3 or 4 bolts) that holds the mainshaft bearing in... it's behind/around the diff pinion.
It clears a 3.44 pinion, maybe a 3.2, any taller ratio and you'll have to bore it out slightly.
PostPosted: Tue Nov 17, 2009 6:57 pm
Thanks
Now to find one
:cry:
Users browsing this forum: No registered users and 112 guests
