It is currently Fri Jun 20, 2025 6:42 pm
PostPosted: Tue Mar 15, 2005 7:22 pm
Having pinging problems with my van. I've change the plugs leads, dizzy cap, I left the points cause they looked fine, but still might replace them and the condensor. The problem is it's pinging at higher revs (well high revs for a 35 y/o stocko 1100). The problem is inconsistant, but more often than not the problem is there. If the problem is there, it varies from undrivable to almost nonexistant.
So... I was thinking it could be that the needle is worn?
What's the standard needle from a HS2 on a Mini K 1100?
EDIT/ When the problem is really bad, it's right through the rev range.
PostPosted: Tue Mar 15, 2005 8:09 pm
More than likely the advance mechanism in the dizzy has had it, as you say it's 35 yo.
Time to get thee a Pulsar dizzy... cheaper & better than fixing the old Lucarse! :lol:
ps. worn needle will make it rich, less likely to ping..
PostPosted: Tue Mar 15, 2005 8:35 pm
How "bolt in" is a pulsar dizzy once modded? Do I need to play with the advance curv or anything (I don't know how, ya see!).
PostPosted: Tue Mar 15, 2005 9:04 pm
I don't know but the Owner has asked for directions :roll:
Mods Pular Dizzy :lol:
Sorry mate :!:
PostPosted: Tue Mar 15, 2005 9:17 pm
Mods are detailed in the dizzy thread, or on J_A_M's site.
Basically bolt it in, fire it up, set timing with strobe light. Tear up and down the road and have a fiddle. :wink:
Advance curve is pretty good stock. Haven't fitted one yet that didn't go better!
