It is currently Fri Aug 15, 2025 6:37 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 100, 101, 102, 103, 104, 105, 106 ... 568  Next
PostPosted: Fri Nov 20, 2009 4:19 pm
i went fishin with some mates. sh1t it was hot, but the water was good
PostPosted: Fri Nov 20, 2009 5:10 pm
Got an old spray bottle of windex to be used for decoking my engine from my parents house which emptied itself onto my mail on the way back :roll:
Copper 4 lyfe!
PostPosted: Fri Nov 20, 2009 6:36 pm
Finished the 'A' Panel :mrgreen:
David L
PostPosted: Fri Nov 20, 2009 6:54 pm
Nice job Wombat and congratulations on the 5000!
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Fri Nov 20, 2009 7:59 pm
looks spot on David 8)
me nothing during the week but expect to get something done during the week on both of them :lol:
PostPosted: Fri Nov 20, 2009 8:17 pm
I reckon you might want to take the paint back and tell em the colour match is wrong :lol:
Otherwise, looks good mate :wink:
PostPosted: Fri Nov 20, 2009 8:18 pm
Picked up the motor from the neighbours place(only took me a week) and picked up the crank for motor no.2
PostPosted: Sat Nov 21, 2009 10:37 am
Did valve clearances, opened them out to 0.35mm from 0.30mm to experiment. (Car has unknown lumpier than stock cam). Some valve wear it seems, on the exhaust valves mainly I think. Not more than 0.1mm I would think, after 5-10k kms?
Managed to break one spark plug removing it (damn it stop tightening it so much you obsessive-compulsive!) Plugs nice and black-brown. Seemed eager to jump in revs after 2500rpm while driving to buy new plugs. Decided to gap them 0.80mm (pre-gapped) instead of 0.60mm recommended as an experiment.
Sprayed some water down the carb throat, into the vac line. Stumbled a bit, but no smoke? Does that mean I have no carbon buildup?
Doing some drive testing shortly...
Edit: its too $*)&$%# hot to do anything now
Copper 4 lyfe!
PostPosted: Sat Nov 21, 2009 6:28 pm
Busy day:
- Cut and replaced Sill rust on the passenger side
- Put on 4 new tires (Replaced the 17 year old bridgestones :S)
- Balanced tires
- Put new brake cylinders all round (all the old ones were leaking something cronic, explains why my brakes were so shyte)
- Replaced all the brake hoses - all of them had perished, 2 of them were completely blocked with no fluid getting through
- Clean all drums
- Fixed the passenger door which automatically locked itself and wouldnt open without a key a.k.a made it girlfriend friendly 8)
- Replaced shocks all round, apparently they weren't doing anything let alone absorbing any shock.
- Replaced rocker cover gasket which was pissing oil all over the car and drive way
- Replaced cracked and leaking fuel hose - no more fuel smell, and better mileage :)
- Replaced a bush in the gear box, i now need to lift my gear stick to go into reverse - never had to do that in the year i've owned the car...
PostPosted: Sat Nov 21, 2009 9:11 pm
lent on it :lol:
 Post subject: moke
PostPosted: Sat Nov 21, 2009 9:15 pm
Put some new Tail Lights on the moke today :D
PostPosted: Sat Nov 21, 2009 10:51 pm
tightened the sump plug - no more oil leaks! :D
tim
PostPosted: Sat Nov 21, 2009 11:16 pm
Tried to return a KAD product that isn't designed for my car (designed for Rover, I have a Morris), and got quite well verbally abused for it and told to get the ""frig"" (yes a different rude word was used) out of his shop and that I am a con artist! :shock: :cry:
PostPosted: Sun Nov 22, 2009 11:26 am
Saturday
tried a different needle and spring combination in the SU. Tried a few different timing settings aswell.
Replaced the LH cv joint with a new one. reshimmed LH top ball joint as it was a little loose.
Flushed cooling system and replaced coolant.
adjusted rear ride height slightly higher as it was scrapping with 4 people in the car when cornering hard.
and today i will play with the timing again. i am going to try a few different spring combinations in the dizzy and see if can get this dizzy to work like it should be :D
Jason
PostPosted: Mon Nov 23, 2009 3:05 pm
drove her on the road today for the first time in three months since the rebuild started. :D still needs a lot of tuning to be done.
also received another package today, QL5000 driveshaft couplings. ordered 2 thinking it was individual like the rubber uni joints, so now I have two pairs of the QL5000. :oops:
will install tomorrow.
1965 Morris Mini Deluxe - 998cc SC12
Users browsing this forum: Bing [Bot] and 199 guests
