It is currently Sat Jul 26, 2025 11:34 am
PostPosted: Wed Nov 25, 2009 8:49 pm
hey..
i have the proper New fuel pump putting out 2 to 4 psi from mini plus
had this problem with the old pump that was putting out 6.6 psi still got the same problem though.
they are dual 1-1/4 twin su's.
fuel keeps overflowing the passenger side of carby.
how can i stop this?
PostPosted: Wed Nov 25, 2009 9:02 pm
Tomboss Breweros
Probably an obvious question, but is the needle and seat good?
And are you definately hooking up the hoses the right way?
Take off the float bowl lid, put a bit of hose on the inlet, hold the lid upside down and blow into the hose, you should not be able to blow any air through.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Wed Nov 25, 2009 9:05 pm
it's all new recon etc.
i was told just before maybe it is sticking as the carbs sat for a while?
or the seal has gone?
PostPosted: Wed Nov 25, 2009 9:13 pm
Tomboss Breweros
I'd check it using the blow test, it's quick and easy, then you know if you need to look closer at the seal, really the carb sitting shouldn't make much difference,, but it might, check it out.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Wed Nov 25, 2009 9:15 pm
cool mate will do..
i thought maybe the float was sticking?
could that be something to look at also.
PostPosted: Wed Nov 25, 2009 9:20 pm
Tomboss Breweros
You will know as soon as you turn it upside down, it should freely sit down on the needle but not quite compress it (they usually have a little internal sprung pin)
kimini wrote:
Jimmyinamini wrote:
PostPosted: Wed Nov 25, 2009 9:26 pm
ok cool thanks mate :)
PostPosted: Thu Nov 26, 2009 4:08 pm
Sometimes you can get a tiny bit of grit stuck in the needle valve and causes the leak.
Just a hit on the top of the float bowl with the handle of a screwdriver can often cure it. :wink:
PostPosted: Thu Nov 26, 2009 4:16 pm
fixed. needle has bit of crap sticking it down. :D
brooooooooooooooom
PostPosted: Thu Nov 26, 2009 4:24 pm
Good to hear mate, and no thread hijack for a change :lol:
