It is currently Tue Jul 22, 2025 11:41 pm
PostPosted: Wed Nov 25, 2009 8:34 pm
Resident Haemorrhoid
Pulled the plugs today NGK BP6ES and the electrodes were covered in a light brown muck they were only oily on the threads.
Question is do i need to go hotter or cooler or stay the same ???
its a 1098
mtsmini wrote:
Tombo wrote:
PostPosted: Wed Nov 25, 2009 8:36 pm
Are you running Valvemaster additive?
It really craps plugs up bad with brown sh!te...
A light brown to grey deposit is fine. A BP6ES plug is OK in most motors.
Last edited by drmini in aust on Wed Nov 25, 2009 8:38 pm, edited 1 time in total.
PostPosted: Wed Nov 25, 2009 8:37 pm
yes Doc when i remember to add it :oops:
mtsmini wrote:
Tombo wrote:
PostPosted: Wed Nov 25, 2009 8:39 pm
I would seriously NOT run it. Use Flashlube, it's cheaper, and doesn't leave any crap there. 8)
PostPosted: Wed Nov 25, 2009 8:43 pm
Doc,
I just checked the bottle and it is Flash lube not the other stuff and i generally run Mobil premium in it
will it leave that muck if it runs lean??
mtsmini wrote:
Tombo wrote:
PostPosted: Wed Nov 25, 2009 8:45 pm
Nope it shouldn't. Did you run Valvemaster before? More likely to run white if it's lean. If so I'd bung 4 new plugs in...
PostPosted: Wed Nov 25, 2009 8:47 pm
Nope it shouldn't. Did you run Valvemaster before? If so I'd bung 4 new plugs in...
No pretty sure i have always run flash lube in it have run an ethanol blend a couple of times before i read here that it is not a good idea if running SU's
mtsmini wrote:
Tombo wrote:
PostPosted: Wed Nov 25, 2009 9:19 pm
This space for rent
That's because the ethanol eats certain types of rubber, like the O-ring seal in the outlet from the float bowl.
Different brands of fuel will burn differently and leave different deposits.. personally I stay away from Shell and stick to BP Ultimate.
I have found that after lots of K's without cleaning, I get a little brown plaque on my plugs.. I am running Valvemaster additive though. Might give Flashlube a run and see if it clears up! Thanks for the tip, Doc :D
Users browsing this forum: Bing [Bot] and 91 guests
