It is currently Sat Aug 02, 2025 5:01 am
 Post subject: A question
PostPosted: Wed Nov 25, 2009 9:40 pm
i get a one metalic tock (i'm guessing that classed as a ping) on start up sometimes and thats its only when she just fires up. i think it's a little strange and would like to know if anyone else has had the same sort of thing and what is it? is it a problem?
she only does it on start up other then that quiet as a mouse when running.
cheers in advance.
Fiji.
PostPosted: Wed Nov 25, 2009 9:49 pm
yeah probably need to back the timing off a degree or 2,,, or maybe some fresh clean Premium fuel (or both) :-)
PostPosted: Fri Nov 27, 2009 7:39 pm
Could it be your fan just catching your cowling??
 Post subject: Or..
PostPosted: Fri Nov 27, 2009 7:45 pm
Or maybe the big end bolts are loose !!! You better strip the engine and check before it blows apart.
"Let us remove your "SHORTS"
