It is currently Wed Aug 06, 2025 10:30 pm
 Post subject: Not Sure about....
PostPosted: Fri Nov 27, 2009 10:14 pm
hey guys. i have found some wires under the car where the gear lever meets. would they be simply reverse cables?? if they come on the car... or does anyone know what they are if they are normal or anything hahahah!!! cheers
PostPosted: Fri Nov 27, 2009 10:22 pm
If your car has a rod-change gearbox there will be two wires running to the gearshift under the car for the reversing lights.
I think they were white (maybe with a trace?)
PostPosted: Fri Nov 27, 2009 11:17 pm
I seee thanks for that mate. yeah looks like there was a wire up there on the shifter... it must have snapped somehow at somestage, only just got the car so was trying to work out what they were for. it has no reversing lights though, might just rip em out.
PostPosted: Sat Nov 28, 2009 6:29 am
Mods rock!
They are green and one has a black trace.
PostPosted: Sat Nov 28, 2009 6:52 am
Are you sure there is no reversing lights they work off the rear blinkers ,open the boot and check to see if ther is a single or double wire on the rear blinker base if single only no reverse lights
PostPosted: Sat Nov 28, 2009 8:55 am
Coool thanks for all they help people!! ill check it out today:)
...M I N 1 7 1...
