It is currently Fri Aug 15, 2025 7:55 pm
 Post subject: Exhaust valve?
PostPosted: Sat Nov 28, 2009 2:28 pm
grr!! the mini is running as though it is only firing on 3. Compression tested it, and getting between 1000-1200 on cyl 1,2,4 but 3 is only getting around 500. Took the plug out and smoke came out which leads me to believe something is wrong with the exhaust valve? I took the rocker cover off and it seems that all the lifters are dancing like normal.
Help? Please?
PostPosted: Sat Nov 28, 2009 2:49 pm
Mods rock!
Might not be exhaust valve, but while you had the rocker cover off, was there tappet clearance on all valves?
If tappet clearance was OK then you will (at least) need to take the cylinder head off to find out if it is top or bottom end.
PostPosted: Sat Nov 28, 2009 2:53 pm
I don't understand.. how do i check clearances and the such?
PostPosted: Sat Nov 28, 2009 2:59 pm
Search is your friend :)
Cheers Pete
http://www.ausmini.com/forums/viewtopic.php?t=10528
PostPosted: Sat Nov 28, 2009 4:19 pm
ok so i just checked it all. Cyl 3 was out a little bit, so i re-adjusted and did the compression test again, but its still reading around the 500 mark. Also noticed quite a bit of oil in comparison to the other cylinders. This leads me to believe maybe the rings are going? Haven't noticed any blue smoke, but i have notice a little bit of smoke.
PostPosted: Sat Nov 28, 2009 4:23 pm
I would guess that it is a burnt exhaust valve. :cry:
PostPosted: Sat Nov 28, 2009 4:28 pm
New ones are cheap, I'd rip all the others exhausts out too, recut the seats, & fit 4 new valves if there is any doubt.
PostPosted: Sat Nov 28, 2009 4:34 pm
i'll just drop some money into the spare 998 i got sitting in the garage, get it fully rebuilt so it will be reliable...ish.
Recommend me a engine rebuilder to get the job done quickly and right?
PostPosted: Sat Nov 28, 2009 5:23 pm
Mods rock!
Try matt the mini man
PostPosted: Sun Nov 29, 2009 11:55 am
ken at mini automotive in ipswich sorted me out
Users browsing this forum: Phil 850 and 388 guests
