It is currently Wed Jul 23, 2025 2:24 am
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2, 3  Next
 Post subject: KAD Rear disc brakes.
PostPosted: Wed Dec 02, 2009 5:55 pm
Random, but at least the topic heading there!
Has anyone used them? What do folks think of lightening the sprung weight in the rear?
I gear a number of racers use them but are they any good for a reasonably fast road car?
Thanks in advance.
bam
PostPosted: Wed Dec 02, 2009 5:59 pm
I dont have them, but they do work & lightening the unsprung mass is always a good thing. Braking will be unchanged - even drums can lock up the rear easily. They don't like repeated use for handbrake turns, so no suitable for khana cars.
In a road car, there are a lot more areas to remove weight from first.
PostPosted: Wed Dec 02, 2009 6:08 pm
Well I figure removing weight from my wallet counts!
I also reckon the rust and muck cut out to be replaced by genuine metal must count.
Other than tha, for a road car, what can ya do :roll:
PostPosted: Wed Dec 02, 2009 6:11 pm
If you like removing weight from your wallet, start with a f/glass bootlid or carbon fibre, theyl lighten the car and your wallet will float 3 ft off the ground :lol:
PostPosted: Wed Dec 02, 2009 6:16 pm
Mods rock!
I'd actually suggest look first at where the majority of the weight is - at the front - first, then start look elsewhere.
PostPosted: Wed Dec 02, 2009 8:02 pm
you could always put alloy trailing arms and alloy minifin type drums on and save heap more weight if you like lightening your wallet
PostPosted: Wed Dec 02, 2009 8:25 pm
A bit off topic, but I have always wondered how to set up a hydraulic handbrake for the rear end, and if it interferes with the ordinary braking function?
68 Mini
70 Moke
PostPosted: Wed Dec 02, 2009 8:26 pm
Or fit the KAD alloy rear arms ...and then fit the KAD alloy hubs, discs, etct etc..along with a carbon fibre boot lid, boot floor, era bumper (or just do away without one entirely). Just how light do you want your wallet to be :)
Cheers, Ian
PostPosted: Wed Dec 02, 2009 8:28 pm
If you really want to lighten your wallet give all your spare cash to ME :lol: :lol:
http://www.force-racing.co.uk/rear-suspension/
8)
68 Mini
70 Moke
PostPosted: Wed Dec 02, 2009 8:31 pm
Mods rock!
It can be done 'seamlessly'. Standard Hydralic Foot Brakes will work normal and the cable hand brake (if you still retain it) will also work normal.
PostPosted: Wed Dec 02, 2009 8:35 pm
Try searching for hydraulic handbrakes in the search.
Its basically another master cylinder that is plumbed into the rear brake lines. This master is then activated by a lever that can lock the rear brakes hydraulically.
Simplify and add lightness
PostPosted: Wed Dec 02, 2009 8:39 pm
Smarty wrote:
Smarty, fully sick :roll:
PostPosted: Wed Dec 02, 2009 8:44 pm
bamnfi wrote:
Now that is wank factor. With the price tag to match.
Id be going for them if i could afford it.
PostPosted: Wed Dec 02, 2009 9:04 pm
I have a set on my Mini.
They are much lighter than the drums and are still more than capable of locking up the rears. A nice bit of engineering too :)
But as awdmoke said they are not designed for handbrake turns or heavy rear brake bias or left foot braking...
Users browsing this forum: XMK870 and 82 guests
