It is currently Sun Jun 29, 2025 4:02 pm
 Post subject: G13B Timing Belt
PostPosted: Sat Dec 05, 2009 3:31 pm
Hi,
I've just changed my timing belt on the twin cams but I'm not sure if either the cams or the crank have moved. The engine is a pain to get in and out, so I'd like to check it manually. But I don't know how. The crank def moved when I was undoing the balancer, but I can't remember if the belt was tensioned at the time. Is there a link somewhere with pictures?
PostPosted: Sat Dec 05, 2009 3:46 pm
www.redlinegti.com.au
PostPosted: Sat Dec 05, 2009 4:02 pm
Thanks JC.
I'm also checking out Teamswift.com too.
I'm a deckhead for not taking notes/pictures before dissasembling it.
PostPosted: Sat Dec 05, 2009 7:25 pm
Don't get too upset. Consider yourself fortunate you have a motor the was sold new in australia so at least you will be able to find help (the 4efte boys aren't so lucky).
PostPosted: Tue Dec 08, 2009 8:26 am
get yourself a manual..... there are timing marks on the crank pully and cam sprokets.... very simple after you have done it a coulpe of times.... :lol:
PostPosted: Tue Dec 08, 2009 8:28 am
In addition being on the westside of Brisbane you're close to one of Brisbane's best known GTi peeps. Drop me a line if you are after his number.
PostPosted: Tue Dec 08, 2009 8:22 pm
I got the info I was after on the TeamSwift website. I've just finished putting it all back together this arvo after work. Lucky I checked it as it was out a fair bit. About a 1/4 turn of the crank.
I don't really want to buy a book as I don't think the $50 bucks or so is worth it. The engine is no longer in a swift and it's been modded for turbo. So I'd be buying a whole book for one or two pages at the most.
And JC thanks for the offer of the number, I don't think I'm at the engine starting stage yet. The engine has to go back in first. But I'll keep this contact in mind for later.
PostPosted: Tue Dec 08, 2009 8:30 pm
Should I ask who built your subframe?
PostPosted: Tue Dec 08, 2009 8:56 pm
You can ask, but I don't know the answer.
I bought Ben's old car at the start of this year.
http://www.ausmini.com/forums/viewtopic ... light=g13b
There is a list of things to do before it's going again.
Fit new interior (bought from the UK this week)
Fit new Sump and turbo oil return line. The old sump was cracked and leaked oil everywhere
Finish cleaning the leaked oil off the motor
Refit motor
Buy and fit aftermarket ECU
Fix O/S sill, and boot under tyre
Paint (get rid of the Ford Citric Acid)
ETC...
PostPosted: Tue Dec 08, 2009 9:44 pm
Aaaaah, that one. Know it well. Ah the memories.
PostPosted: Wed Dec 09, 2009 6:30 am
So that's what happened the Benny's Clubman.
Wonder what happened to it.
Good luck with it WantOne
Tricky
P.S. Remember the Story Bridge JC??
