It is currently Mon Jun 23, 2025 10:21 pm
Post new topic Reply to topic  [ 353 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15, 16 ... 24  Next
PostPosted: Sun Dec 06, 2009 10:31 pm
That's looking awesome... where'd you get all the suspension gear? Same place or bits and pieces from here and there?
Answer the Question....
BUT always Question the Answer
PostPosted: Mon Dec 07, 2009 6:15 pm
Thanks guys
Most of the gear i got from minisport in adelaide, 2 days and on my doorstep (i've waited long enough for this build), really helpfulguys too. Other stuff from my local mini supplier Toby at minispares in seaford
cheers Hallsey
PostPosted: Wed Dec 09, 2009 7:35 pm
GOOD NEWS BAD NEWS AWESOME NEWS
First the good news,
I got my fuel system temporarily fitted so i can fire the ol girl up, gotta make a bracket for the surge tank and pump. But it's all working fine.
Bad news is i had to finalise some wiring, the motor was turning over but i had no power to the coil , ignitor,and injectors.
i spent 2 nights trying to work out what i had cut out that i should'nt have, to no avail.
I found a beared wire which was rubbing on the firewall which had blown a fuse, repair wire change fuse, problem solved?
NO
By this stage i thought i might have spiked the computer, so i sent it away to get tested, But all came back good, no problems
I then tested power to the coil again and had power, and at the injectors.
you beauty i thought,so i plugged in the computer and had no power.
Steam pouring out of the ears by this stage, i went inside for lunch and watch some v8's
Came back out and started following wires.
WAIT FOR IT
Came across an earth i had missed
When i had power and then did'nt ,the fuse box was resting on the floor ontop of the earth when i plugged the computer in i must have moved the fuse box (and the earth)
Anyway earthed out the wire and of course had power everwhere,VERY VERY ANNOYING
Now the good news
2 cranks of the starter and she fired into life, so good to hear it after 2 years
YEEE HAAA
Cheers Hallsey
PostPosted: Wed Dec 09, 2009 8:42 pm
Excellent news Hallsey, must be a great boost to hear it run.
How close to getting on the road is it? Will it make an appearance on the weekend?
Madmorrie
PostPosted: Thu Dec 10, 2009 7:53 am
Thats great news Hallsey - another milestone reached!
Whats left now to do?
PostPosted: Thu Dec 10, 2009 9:10 am
Good show.
With the placment of your filter, is that before or after the pump?
PostPosted: Thu Dec 10, 2009 4:50 pm
Yep good news all i'm pretty stoked,
(Gotta learn to do the quote thing)
G,day Ross still a while off yet, i'll be at Watto's on sunday still with the trusty ol A series in her .
G,day Tricky, just got drive shafts,exhaust and the wiring (shortning and lengthing)Then the engineer comes back and if he's happy it all gets transfered over to the good shell,then he comes back and signs her off.
Does'nt sound that much does it (if you say it quick)
JC
That filter you see is after the pump but there's another one before it out of sight
Cheers Hallsey
PostPosted: Sat Dec 12, 2009 6:29 pm
Excellent milestone Hallsey!
I think I missed the exact same earth before I got mine running. Short earth wire going to the top of the gearbox just under the fusebox[or at least where my fusebox is]?
If you ever need to check that your ecu or any other component works I have a few spares, (incl. ecu) you could try out. :wink:
-James.
Toyota 4EFTE Powered Minivan.
PostPosted: Sat Jan 09, 2010 3:32 pm
Hi Guys
Need some help
Initially i was going to use the starlet steering column,made brackets
cut the spline off the bottom of the mini shaft and welded it to the starlet
shaft, all was sweet until the engineer came and said it was a no no .
Anything that is welded to do with steering has to be X rayed, so i put it
in the to hard basket and was just going to fit the starlet binicle to the
mini column .
The ploblem i have now is trying to get the horn and indicators self
canceling to work.
I'm thinking of moulding the bottom of the starlet into my SAAS wheel
but i thought I'd check and see who is running this combo and what did
you do or I'm open to everyone's brain trust
The piece on top is the bottom of the starlet steering wheel
I'm thinking of moulding this to the SAAS wheel
Cheers Hallsey
PostPosted: Fri Apr 30, 2010 8:32 pm
Hi guys
just a small update to let you know i'm still plodding away.
Kids have started their race season so time is limited now but i've
been making slow progress.
I had a drive of James's (77 clubby van) car and i must say it was awesome
Well i've started the dash ,the first stage anyway
Well i should say i roped my son (a chippy by trade) to help with
the making
And cut some holes
And in the car
On a side note i have been busy with other stuff that has interupted
working on the mini
1st of all after years of " I must get around to that" I painted my
daily driver
And i've also bought my next project DA VAN
Cheers Hallsey
PostPosted: Fri Apr 30, 2010 9:12 pm
Hey mate,
Glad there is progress. Wish I could say the same.
That ute has come up awesome, well done. What are the plans for the van then??
Madmorrie
PostPosted: Sat May 01, 2010 9:40 am
G'day Madmorrie
Yeah ute come up good,looks a lot neater,
Van ,Well i have'nt decided yet.
How are you going with the brake saga,any headway?
Cheers Hallsey
PostPosted: Sat May 01, 2010 11:03 am
Current plan is to use the blingy tarox discs and calipers and get new disc and hub adapters made. Engineer reckons he can get a cheaper quote than $1000.
I hope he can too.
Madmorrie
PostPosted: Mon May 03, 2010 9:05 am
The dash looks good. How are you thinking of finishing it? Vinyl covering or paint or...?
That hilux came up a treat too. Yamaha blue? :P :lol: :P :lol:
P.S: Can't wait to see what you do with the van! :wink:
-James.
PostPosted: Mon May 03, 2010 11:07 am
I hope he can too.
Madmorrie
Tarox make a pretty nice looking adapter for the calipers to adapt to the hubs...
Life's a garden.... Dig It!
